[petsc-users] ILU and Block Gauss Seidel smoothing
Gianluca Meneghello gianmail at gmail.com
Mon Jul 18 13:36:36 CDT 2011
Barry,
I'm actually using ilu as a smoother inside a multigrid cycle. Does in this case make sense to use ksppreonly? Or should I use Richardson?
Thanks
Il giorno 18/lug/2011, alle ore 20:14, Barry Smith <bsmith at mcs.anl.gov> ha scritto:
> On Jul 18, 2011, at 9:43 AM, Gianluca Meneghello wrote:
>> Barry,
>> thanks again for your input. That would be really good.
>> When executing my program with the options you suggested I obtain
>> various errors (unknown pc etc) so I tried to figure out how to avoid
>> them. Is it something like this what you intended?
>> ./main
>> -mg_pc_type composite
>> -mg_pc_composite_pcs ilu,ilu
>> -mg_ksp_type preonly
>    I don't think you want this one. It says not to use a Krylov method on the outside; the preconditioner will just apply the two ILU triangular and that is it.  In other words it won't even solve the linear system. You likely want -mg_ksp_type gmres
>   Barry
>> -mg_sub_0_pc_factor_mat_ordering_type FESOrder
>> -mg_sub_1_pc_factor_mat_ordering_type FWSOrder
>> -mg_pc_composite_type multiplicative
>> -mg_ksp_view
>> provided that
>> KSPSetOptionsPrefix(ksp,"mg_");
>> has been applied to the KSP I want to modify.
>> Thanks again
>> Gianluca
>> On 13 July 2011 15:33, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>> On Jul 13, 2011, at 4:02 AM, Gianluca Meneghello wrote:
>>>> Thanks Barry.
>>>> What I'm doing at the moment in order to pass the ordering to the PC is
>>>> PCFactorSetMatOrderingType(PC,"FESOrder");
>>>> where the FESOrder(...) function computes the ordering and has been
>>>> registered in the main function with
>>>> MatOrderingRegister("FESOrder",0,"FESOrder",FESOrder);
>>>> The same is done for al the different orderings I'm using inside the
>>>> PCSHELL suggested by Jed.
>>>> My understanding is that the FESOrder(...) function is evaluated every
>>>> time the PCApply(...) function is called.
>>>  Definitely not. Looking at PCSetUp_ILU()
>>> } else {
>>>   if (!pc->setupcalled) {
>>>     /* first time in so compute reordering and symbolic factorization */
>>>     ierr = MatGetOrdering(pc->pmat,((PC_Factor*)ilu)->ordering,&ilu->row,&ilu->col);CHKERRQ(ierr);
>>> it will actually call the ordering routine a TOTAL of ONE TIME if you use SAME_NONZERO_PATTERN to KSPSetOperators() or PCSetOperators(). (it is smart enough to reuse the ordering).
>>>  BTW: I don't think you even need to use a PCSHELL preconditioner. You can get the same effect with a PCCOMPOSITE.  Just create a single KSP in the usual way and use the options
>>> -pc_type composite -pc_composite_type ilu,ilu -sub_0_ksp_type preonly -sub_1_ksp_type preonly -sub_0_pc_factor_mat_ordering_type FESOrder -sub_1_pc_factor_mat_ordering_type anotherorder somethingelse
>>>  Barry
>>>> If there was a way to store the IS containing the ordering — or any
>>>> other array — into the shell context (this I know how to do that) and
>>>> the pass the IS directly to the preconditioner instead of using
>>>> PCFactorSetMatOrderingType would be the best solution for me.
>>>> Thanks
>>>> Gianluca
>>>> On 12 July 2011 20:15, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>>>> On Jul 12, 2011, at 3:47 AM, Gianluca Meneghello wrote:
>>>>>> Jed, thanks for your answer.
>>>>>> This is exactly what I was looking for (it took me some time to test it...).
>>>>>> Let me ask you a couple of additional questions:
>>>>>> 1) in this configuration, is there an alternative way to pass the
>>>>>> ordering to the preconditioner? Becuse my ordering depends on the grid
>>>>>> an not on the solution, it is constant during all the computations and
>>>>>> I have no advantage on calling the function that creates multiple
>>>>>> times (the pc is built and destroyed several times).
>>>>>  Not sure exactly what you want here. You can put the ordering information in the shell context and just keep it there forever and don't need to to recompute.
>>>>>   PCShellSet/GetContext()?
>>>>>> 2) what's the best way to make the shell pc selectable from the option
>>>>>> database, so that it can be replaced with more standard ones?
>>>>>       /* here the user can provide -pc_type shell or ilu or whatever */
>>>>>       KSPSetFromOptions(ksp);
>>>>>       KSPGetPC(ksp,&pc);
>>>>>       /* the following lines will only do something if the user selected the PCType of shell otherwise they are ignored */
>>>>>       PCShellSetContext(pc,....)
>>>>>       PCShellSetSetUp(pc,....)
>>>>>       PCShellSetApply(pc,.....)
>>>>>  Barry
>>>>>> Thanks
>>>>>> Gianluca
>>>>>> On 1 July 2011 14:43, Jed Brown <jed at 59a2.org> wrote:
>>>>>>> On Fri, Jul 1, 2011 at 07:11, Gianluca Meneghello <gianmail at gmail.com>
>>>>>>> wrote:
>>>>>>>> I've tried to implement Jed's solution as it was looking faster to
>>>>>>>> try. This is what I came up with for two different orders, FENOrder
>>>>>>>> and FWNOrder respectively
>>>>>>>> 283       KSP ksp;
>>>>>>>> 284       PC pc;
>>>>>>>> 285
>>>>>>>> 286       ierr = KSPCreate(PETSC_COMM_WORLD,&ksp);  CHKERRQ(ierr);
>>>>>>>> 287       ierr = KSPSetOptionsPrefix(ksp,"mg_");    CHKERRQ(ierr);
>>>>>>>> 288       ierr = KSPSetOperators(ksp,J,J,SAME_NONZERO_PATTERN);
>>>>>>>> CHKERRQ(ierr);
>>>>>>>> 289       ierr = KSPSetFromOptions(ksp);    CHKERRQ(ierr);
>>>>>>>> 290       ierr = KSPGetPC(ksp,&pc);         CHKERRQ(ierr);
>>>>>>>> 291       ierr = PCFactorSetFill(pc,1);     CHKERRQ(ierr);
>>>>>>>> 292       ierr = PCFactorSetMatOrderingType(pc,"FENOrder"); CHKERRQ(ierr);
>>>>>>>> 293       ierr = KSPSolve(ksp,b,x); CHKERRQ(ierr);
>>>>>>>> 294       ierr = KSPDestroy(&ksp);  CHKERRQ(ierr);
>>>>>>>> 295
>>>>>>>> 296       ierr = KSPCreate(PETSC_COMM_WORLD,&ksp);  CHKERRQ(ierr);
>>>>>>>> 297       ierr = KSPSetOptionsPrefix(ksp,"mg_");    CHKERRQ(ierr);
>>>>>>>> 298       ierr = KSPSetOperators(ksp,J,J,SAME_NONZERO_PATTERN);
>>>>>>>> CHKERRQ(ierr);
>>>>>>>> 299       ierr = KSPSetFromOptions(ksp);    CHKERRQ(ierr);
>>>>>>>> 300       ierr = KSPGetPC(ksp,&pc);         CHKERRQ(ierr);
>>>>>>>> 301       ierr = PCFactorSetFill(pc,1);     CHKERRQ(ierr);
>>>>>>>> 302       ierr = PCFactorSetMatOrderingType(pc,"FWNOrder"); CHKERRQ(ierr);
>>>>>>>> 303       ierr = KSPSolve(ksp,b,x); CHKERRQ(ierr);
>>>>>>>> 304       ierr = KSPDestroy(&ksp);  CHKERRQ(ierr);
>>>>>>> It looks like you are putting all of this in PCApply_YourShell(). I suggest
>>>>>>> making
>>>>>>> struct YourShellContext {
>>>>>>>  PC fenpc,fwnpc;
>>>>>>>  Vec work;
>>>>>>>  PetscBool issetup;
>>>>>>> Then pass a pointer to this thing in when you create the PCShell. Then
>>>>>>> something like
>>>>>>> PCSetUp_YourShell(PC pc) {
>>>>>>> struct YourShellContext *ctx;
>>>>>>> Mat A,B;
>>>>>>> MatStructure mstr;
>>>>>>> const char *prefix;
>>>>>>> char iprefix[256];
>>>>>>> PCShellGetContext(pc,&ctx);
>>>>>>> PCGetOptionsPrefix(pc,&prefix);
>>>>>>> if (!ctx->issetup) {
>>>>>>>  ierr = MatGetVecs(A,&ctx->work,PETSC_NULL);
>>>>>>>  PCCreate(comm,&ctx->fenpc);
>>>>>>>  PCSetType(ctx->fenpc,PCILU);
>>>>>>>  PCFactorSetFill(ctx->fenpc,1);
>>>>>>>  PCFactorSetMatOrderingType(ctx->fenpc,"FENOrder");
>>>>>>>  snprintf(iprefix,sizeof iprefix,"%sfen",prefix);
>>>>>>>  PCSetOptionsPrefix(ctx->fenpc,iprefix);
>>>>>>>  PCSetFromOptions(ctx->fenpc);
>>>>>>>  /* Same as above for ctx->fwnpc */
>>>>>>> PCGetOperators(pc,&A,&B,&mstr);
>>>>>>> PCSetOperators(ctx->fenpc,A,B,mstr);
>>>>>>> PCSetOperators(ctx->fwnpc,A,B,mstr);
>>>>>>> PCSetUp(ctx->fenpc);
>>>>>>> PCSetUp(ctx->fwnpc);
>>>>>>> ctx->issetup = PETSC_TRUE;
>>>>>>> Then in PCApply_YourShell(PC pc,Vec X,Vec Y) {
>>>>>>> PCGetOperators(pc,&A,PETSC_NULL,PETSC_NULL);
>>>>>>> PCApply(ctx->fenpc,X,Y); /* apply first ordering */
>>>>>>> VecScale(Y,-1.0);
>>>>>>> MatMultAdd(A,Y,X,ctx->work); /* Compute fresh residual */
>>>>>>> PCApply(ctx->fwnpc,ctx->work,Y);
>>>>>>>> I don't know if this is what you intended... is there a way to make
>>>>>>>> KSP recompute the factorization with the different ordering without
>>>>>>>> destroying and recreating the KSP?
>>>>>>> Store both as in the code above.
>>>>>>>> Concerning Barry's option, js it possible to use the PETSc ilu
>>>>>>>> factorization function (and eventually the ones provided by external
>>>>>>>> libraries) inside my PCSHELL, passing it the various ordering I will
>>>>>>>> need? If so, what's the best way to access it?
>>>>>>> Does the code above answer this question?
>>>>>> "[Je pense que] l'homme est un monde qui vaut des fois les mondes et
>>>>>> que les plus ardentes ambitions sont celles qui ont eu l'orgueil de
>>>>>> l'Anonymat" -- Non omnibus, sed mihi et tibi
>>>>>> Amedeo Modigliani
>>>> Amedeo Modigliani
>> Amedeo Modigliani
