[petsc-users] ILU and Block Gauss Seidel smoothing
Gianluca Meneghello gianmail at gmail.com
Mon Jul 18 09:43:17 CDT 2011
Barry,
thanks again for your input. That would be really good.
When executing my program with the options you suggested I obtain
various errors (unknown pc etc) so I tried to figure out how to avoid
them. Is it something like this what you intended?
./main
-mg_pc_type composite
-mg_pc_composite_pcs ilu,ilu
-mg_ksp_type preonly
-mg_sub_0_pc_factor_mat_ordering_type FESOrder
-mg_sub_1_pc_factor_mat_ordering_type FWSOrder
-mg_pc_composite_type multiplicative
-mg_ksp_view
provided that
KSPSetOptionsPrefix(ksp,"mg_");
has been applied to the KSP I want to modify.
Thanks again
Gianluca
On 13 July 2011 15:33, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Jul 13, 2011, at 4:02 AM, Gianluca Meneghello wrote:
>> Thanks Barry.
>> What I'm doing at the moment in order to pass the ordering to the PC is
>> PCFactorSetMatOrderingType(PC,"FESOrder");
>> where the FESOrder(...) function computes the ordering and has been
>> registered in the main function with
>> MatOrderingRegister("FESOrder",0,"FESOrder",FESOrder);
>> The same is done for al the different orderings I'm using inside the
>> PCSHELL suggested by Jed.
>> My understanding is that the FESOrder(...) function is evaluated every
>> time the PCApply(...) function is called.
>   Definitely not. Looking at PCSetUp_ILU()
>  } else {
>    if (!pc->setupcalled) {
>      /* first time in so compute reordering and symbolic factorization */
>      ierr = MatGetOrdering(pc->pmat,((PC_Factor*)ilu)->ordering,&ilu->row,&ilu->col);CHKERRQ(ierr);
> it will actually call the ordering routine a TOTAL of ONE TIME if you use SAME_NONZERO_PATTERN to KSPSetOperators() or PCSetOperators(). (it is smart enough to reuse the ordering).
>   BTW: I don't think you even need to use a PCSHELL preconditioner. You can get the same effect with a PCCOMPOSITE.  Just create a single KSP in the usual way and use the options
> -pc_type composite -pc_composite_type ilu,ilu -sub_0_ksp_type preonly -sub_1_ksp_type preonly -sub_0_pc_factor_mat_ordering_type FESOrder -sub_1_pc_factor_mat_ordering_type anotherorder somethingelse
>   Barry
>> If there was a way to store the IS containing the ordering — or any
>> other array — into the shell context (this I know how to do that) and
>> the pass the IS directly to the preconditioner instead of using
>> PCFactorSetMatOrderingType would be the best solution for me.
>> Thanks
>> Gianluca
>> On 12 July 2011 20:15, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>> On Jul 12, 2011, at 3:47 AM, Gianluca Meneghello wrote:
>>>> Jed, thanks for your answer.
>>>> This is exactly what I was looking for (it took me some time to test it...).
>>>> Let me ask you a couple of additional questions:
>>>> 1) in this configuration, is there an alternative way to pass the
>>>> ordering to the preconditioner? Becuse my ordering depends on the grid
>>>> an not on the solution, it is constant during all the computations and
>>>> I have no advantage on calling the function that creates multiple
>>>> times (the pc is built and destroyed several times).
>>>   Not sure exactly what you want here. You can put the ordering information in the shell context and just keep it there forever and don't need to to recompute.
>>>    PCShellSet/GetContext()?
>>>> 2) what's the best way to make the shell pc selectable from the option
>>>> database, so that it can be replaced with more standard ones?
>>>        /* here the user can provide -pc_type shell or ilu or whatever */
>>>        KSPSetFromOptions(ksp);
>>>        KSPGetPC(ksp,&pc);
>>>        /* the following lines will only do something if the user selected the PCType of shell otherwise they are ignored */
>>>        PCShellSetContext(pc,....)
>>>        PCShellSetSetUp(pc,....)
>>>        PCShellSetApply(pc,.....)
>>>   Barry
>>>> Thanks
>>>> Gianluca
>>>> On 1 July 2011 14:43, Jed Brown <jed at 59a2.org> wrote:
>>>>> On Fri, Jul 1, 2011 at 07:11, Gianluca Meneghello <gianmail at gmail.com>
>>>>> wrote:
>>>>>> I've tried to implement Jed's solution as it was looking faster to
>>>>>> try. This is what I came up with for two different orders, FENOrder
>>>>>> and FWNOrder respectively
>>>>>> 283       KSP ksp;
>>>>>> 284       PC pc;
>>>>>> 285
>>>>>> 286       ierr = KSPCreate(PETSC_COMM_WORLD,&ksp);  CHKERRQ(ierr);
>>>>>> 287       ierr = KSPSetOptionsPrefix(ksp,"mg_");    CHKERRQ(ierr);
>>>>>> 288       ierr = KSPSetOperators(ksp,J,J,SAME_NONZERO_PATTERN);
>>>>>> CHKERRQ(ierr);
>>>>>> 289       ierr = KSPSetFromOptions(ksp);    CHKERRQ(ierr);
>>>>>> 290       ierr = KSPGetPC(ksp,&pc);         CHKERRQ(ierr);
>>>>>> 291       ierr = PCFactorSetFill(pc,1);     CHKERRQ(ierr);
>>>>>> 292       ierr = PCFactorSetMatOrderingType(pc,"FENOrder"); CHKERRQ(ierr);
>>>>>> 293       ierr = KSPSolve(ksp,b,x); CHKERRQ(ierr);
>>>>>> 294       ierr = KSPDestroy(&ksp);  CHKERRQ(ierr);
>>>>>> 295
>>>>>> 296       ierr = KSPCreate(PETSC_COMM_WORLD,&ksp);  CHKERRQ(ierr);
>>>>>> 297       ierr = KSPSetOptionsPrefix(ksp,"mg_");    CHKERRQ(ierr);
>>>>>> 298       ierr = KSPSetOperators(ksp,J,J,SAME_NONZERO_PATTERN);
>>>>>> CHKERRQ(ierr);
>>>>>> 299       ierr = KSPSetFromOptions(ksp);    CHKERRQ(ierr);
>>>>>> 300       ierr = KSPGetPC(ksp,&pc);         CHKERRQ(ierr);
>>>>>> 301       ierr = PCFactorSetFill(pc,1);     CHKERRQ(ierr);
>>>>>> 302       ierr = PCFactorSetMatOrderingType(pc,"FWNOrder"); CHKERRQ(ierr);
>>>>>> 303       ierr = KSPSolve(ksp,b,x); CHKERRQ(ierr);
>>>>>> 304       ierr = KSPDestroy(&ksp);  CHKERRQ(ierr);
>>>>> It looks like you are putting all of this in PCApply_YourShell(). I suggest
>>>>> making
>>>>> struct YourShellContext {
>>>>>   PC fenpc,fwnpc;
>>>>>   Vec work;
>>>>>   PetscBool issetup;
>>>>> Then pass a pointer to this thing in when you create the PCShell. Then
>>>>> something like
>>>>> PCSetUp_YourShell(PC pc) {
>>>>> struct YourShellContext *ctx;
>>>>> Mat A,B;
>>>>> MatStructure mstr;
>>>>> const char *prefix;
>>>>> char iprefix[256];
>>>>> PCShellGetContext(pc,&ctx);
>>>>> PCGetOptionsPrefix(pc,&prefix);
>>>>> if (!ctx->issetup) {
>>>>>   ierr = MatGetVecs(A,&ctx->work,PETSC_NULL);
>>>>>   PCCreate(comm,&ctx->fenpc);
>>>>>   PCSetType(ctx->fenpc,PCILU);
>>>>>   PCFactorSetFill(ctx->fenpc,1);
>>>>>   PCFactorSetMatOrderingType(ctx->fenpc,"FENOrder");
>>>>>   snprintf(iprefix,sizeof iprefix,"%sfen",prefix);
>>>>>   PCSetOptionsPrefix(ctx->fenpc,iprefix);
>>>>>   PCSetFromOptions(ctx->fenpc);
>>>>>   /* Same as above for ctx->fwnpc */
>>>>> PCGetOperators(pc,&A,&B,&mstr);
>>>>> PCSetOperators(ctx->fenpc,A,B,mstr);
>>>>> PCSetOperators(ctx->fwnpc,A,B,mstr);
>>>>> PCSetUp(ctx->fenpc);
>>>>> PCSetUp(ctx->fwnpc);
>>>>> ctx->issetup = PETSC_TRUE;
>>>>> Then in PCApply_YourShell(PC pc,Vec X,Vec Y) {
>>>>> PCGetOperators(pc,&A,PETSC_NULL,PETSC_NULL);
>>>>> PCApply(ctx->fenpc,X,Y); /* apply first ordering */
>>>>> VecScale(Y,-1.0);
>>>>> MatMultAdd(A,Y,X,ctx->work); /* Compute fresh residual */
>>>>> PCApply(ctx->fwnpc,ctx->work,Y);
>>>>>> I don't know if this is what you intended... is there a way to make
>>>>>> KSP recompute the factorization with the different ordering without
>>>>>> destroying and recreating the KSP?
>>>>> Store both as in the code above.
>>>>>> Concerning Barry's option, js it possible to use the PETSc ilu
>>>>>> factorization function (and eventually the ones provided by external
>>>>>> libraries) inside my PCSHELL, passing it the various ordering I will
>>>>>> need? If so, what's the best way to access it?
>>>>> Does the code above answer this question?
>>>> "[Je pense que] l'homme est un monde qui vaut des fois les mondes et
>>>> que les plus ardentes ambitions sont celles qui ont eu l'orgueil de
>>>> l'Anonymat" -- Non omnibus, sed mihi et tibi
>>>> Amedeo Modigliani
>> Amedeo Modigliani
Amedeo Modigliani
