[petsc-users] PETSc recommended visualization packages
Lisandro Dalcin dalcinl at gmail.com
Thu Jul 14 17:34:42 CDT 2011
On 14 July 2011 18:33, Ethan Coon <ecoon at lanl.gov> wrote:
> On Thu, 2011-07-14 at 17:47 -0300, Lisandro Dalcin wrote:
>> 1) readMatDense() is wrong. The I,J,V arrays are the CSR structure,
>> not the COO (coordinate) format, Then you cannot simply:
> Ok, thanks, I wasn't sure of which format you were using,
Well, PETSc's AIJ matrices are CSR in memory (but not in disk, binary
files store row counts instead of  row pointers)
>> 2) It would be nice to provie a 'scipy' Mat format returning a
>> 'scipy.sparse.csr_matrix' instance. A possible implementation would
>> be:
> Agreed, I considered doing that as the default for sparse, but wasn't
> sure what others would want.  Providing both makes sense.
Note however that this would require a SciPy installation.
PS: Sorry for not being more helpful and contributing actual code, but
I'm really busy.
Lisandro Dalcin
CIMEC (INTEC/CONICET-UNL)
Predio CONICET-Santa Fe
Colectora RN 168 Km 472, Paraje El Pozo
3000 Santa Fe, Argentina
Tel: +54-342-4511594 (ext 1011)
Tel/Fax: +54-342-4511169
