[petsc-users] Field dependent stencil in DAs
Matthew Knepley
knepley at gmail.com
Thu Jul 14 12:42:08 CDT 2011
On Thu, Jul 14, 2011 at 5:31 PM, Kevin Green <Kevin.Green at uoit.ca> wrote:
> From: petsc-users-bounces at mcs.anl.gov [petsc-users-bounces at mcs.anl.gov] On
> Behalf Of Jed Brown [jedbrown at mcs.anl.gov]
> Sent: Monday, July 11, 2011 7:38 PM
> To: PETSc users list
> Subject: Re: [petsc-users] Field dependent stencil in DAs
> On Mon, Jul 11, 2011 at 18:28, Kevin Green <Kevin.Green at uoit.ca<mailto:
> Kevin.Green at uoit.ca>> wrote:
> Essentially, I'm (currently) looking to numerically solve a system of 5
> time dependent equations, but only 1 of the fields is involved with spatial
> derivatives. Now, I've found a couple of ways to do this, either by
> introducing a Field struct cf.
> ${PETSC_DIR}/src/snes/examples/tutorials/ex19.c, or by changing one of the
> various ts examples to use DAVecGetArrayDOF(...). Would there be any
> performance difference between introducing a Field struct compared to
> DAVecGetArrayDOF(...)? Intuitively, I would think not...but I suppose I
> should ask since I'm here anyway.
> I like using field structs because then I get to use names instead of
> numbers for my fields and because there is one less level of pointer
> indirection.
> Now the real reason I came: Is there some sort of mask that can be applied
> to the DAs that would turn off the communication of ghost points for some
> degrees of freedom? I assume that the communication structures are set up
> so that only a single message needs to be passed between communicating
> processes on update, but this still results in passing 5X the data that I
> have to. Any comment on this would be much appreciated.
> DMDASetBlockFills()
> Thank you Jed, this is exactly what I was looking for. In the most recent
> version, it appears to be named as just DASetBlockFills().
Its DMDASetBlockFills() in petsc-dev, and DASetBlockFills() in petsc 3.1
Matt
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110714/0875045f/attachment.htm>
