[petsc-users] MPI v. Pthreads ?
    John Chludzinski
    jchludzinski at gmail.com
    Sun Jul 10 13:15:21 CDT 2011
"If you don't have a real MPI installed"?
I installed (on Cygwin) using: ./configure CC=gcc FC=gfortran
--download-mpich=1 PETSC_ARCH=arch-cygwin-gnu
I've compiled some example MPI code using mpicc. And I've run the generated
executable with: mpiexec -n <some int> <executable>.
"ps" says it created n-number of processes.
But it is on a 2-proc/4-core Windows box running Cygwin (of course, not
configured as a cluster).
Do I have "real MPI" installed?
---John
On Sun, Jul 10, 2011 at 2:00 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> On Sun, Jul 10, 2011 at 12:57, John Chludzinski <jchludzinski at gmail.com>wrote:
>> So if host the "new and improved" PETSc on a mult--proc/multi-core Linux
>> workstation (or in my case, a mult--proc/multi-core Windows workstation
>> running Cygwin), not configured as a cluster, I would be using pthreads and
>> not MPI?
> If it is a single machine, you would be able to use any combination from
> all separate MPI processes to one process. MPI calls won't go away, all the
> XXCreate() functions will still have the MPI_Comm argument. You'll be able
> to use MPIUNI if you don't have a real MPI installed.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110710/74e4346b/attachment.htm>
