[petsc-users] Controlling ML
Fri Jul 8 13:39:58 CDT 2011
There are not setters fo every PCML option. Regardless, you should set a
different prefix for each solver, then you can control them independently.
On Jul 8, 2011 1:31 PM, "John Fettig" <john.fettig at gmail.com> wrote:
> Is there any way to control ML other than the options database? For
> example, I want to set -pc_ml_maxNlevels 3, but there seems to be no
> way to do it other than
> a) the command line or
> b) PetscOptionsSetValue("-pc_ml_maxNlevels","3");
> This doesn't make it easy if you want to have more than one PCML.
> John
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110708/b03181d4/attachment.htm>
