[petsc-users] A Beginner Question
Stefan Kolb
skolb at rocketmail.com
Tue Jul 5 09:04:08 CDT 2011
Hi all,
i have written a littel test program, to check how PETSc stores a matrix across two processes.
static char help[] = "PETSc test";
#include "stdio.h"
#include "petscksp.h"
int main(int argc,char **args)
Mat A;
PetscInt N=100,M=100, row_start = 0, column_start = 0, row_end = 0, column_end = 0, rank = 0, local_rows = 0, local_columns = 0,nproc=0;
PetscErrorCode ierr;
PetscScalar value =0.;
PetscInitialize(&argc,&args,(char *)0,help);
MPI_Comm_rank(PETSC_COMM_WORLD,&rank);
MPI_Comm_size(PETSC_COMM_WORLD,&nproc);
ierr = PetscPrintf(PETSC_COMM_WORLD,"Number of Processes %d\n",nproc);CHKERRQ(ierr);
ierr = MatCreate(PETSC_COMM_WORLD,&A); CHKERRQ(ierr);
ierr = MatSetSizes(A,PETSC_DECIDE, PETSC_DECIDE,N,M); CHKERRQ(ierr);
ierr = MatSetFromOptions(A);CHKERRQ(ierr);
ierr = MatGetOwnershipRange(A,&row_start,&row_end);CHKERRQ(ierr);
ierr = MatGetOwnershipRangeColumn(A,&column_start,&column_end);CHKERRQ(ierr);
ierr = MatGetLocalSize(A,&local_rows,&local_columns);CHKERRQ(ierr);
printf("process=%d \t row_start=%d \t row_end=%d \t column_start=%d \t column_end=%d \t local_rows=%d \t local_columns=%d\n",rank,row_start,row_end,column_start,column_end,local_rows,local_columns);
ierr = MatAssemblyBegin(A,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
ierr = MatAssemblyEnd(A,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
ierr = MatDestroy(A); CHKERRQ(ierr);
ierr = PetscFinalize();CHKERRQ(ierr);
return 0;
The output of the program (using 2 processes) is:
Number of Processes 2
process=0 row_start=0 row_end=50 column_start=0 column_end=50 local_rows=50 local_columns=50
process=1 row_start=50 row_end=100 column_start=50 column_end=100 local_rows=50 local_columns=50
So if the output of my program is right the process with rank=0 owns a matrix with 50 rows and 50 columns in the same way the process with rank=1. This cant be right because on both processes only one half of the global matrix is stored. Wat is the error in my test programm?
I tried to set the local size of the matrix by hand with the command MatSetSizes(A,50, 100,N,M) but then i get an error from PETSc. How can i tell PETSc to store the first 50 rows on process 0 and the next 50 rows on process 1?
Stefan
