[petsc-users] PETSc recommended visualization packages
Stephen Wornom
stephen.wornom at inria.fr
Tue Jul 5 02:25:33 CDT 2011
Jed Brown wrote:
> On Mon, Jul 4, 2011 at 21:44, Barry Smith <bsmith at mcs.anl.gov
> <mailto:bsmith at mcs.anl.gov>> wrote:
> What are the recommended visualization packages for use with PETSc
> (for example making movies of contour plots and isosurfaces) and
> what are the recommended data formats to use to save Vecs for
> visualization?
> VisIt
Any links to VisIt? Goggle produced nothing.
Stephen
> and ParaView are the primary choices. In my experience, VisIt is a
> more complete system, but ParaView is easier to install and probably
> easier to get started with.
> The VTK XML or binary formats are the easiest to get started with. See
> src/ts/examples/tutorials/ex14.c for an example of writing an XML file
> containing two fields on different grids (2D and 3D, structured, but
> deformed) in parallel. All file formats are horrible non-extensible
> crud, usually grown out of a particular application with structured
> grids of low-order/non-exotic basis functions on unstructured grids.
> They tend not to retain enough semantic information to reconstruct a
> state for further computations and also work for visualization without
> needing additional application-provided information.
2004 route des lucioles - BP93
Sophia Antipolis
06902 CEDEX
Tel: 04 92 38 50 54
Fax: 04 97 15 53 51
Type: text/x-vcard
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110705/5d409b73/attachment.vcf>
