[petsc-users] petsc4py DA with dof>1 confusion
Aron Ahmadia
aron.ahmadia at kaust.edu.sa
Mon Jul 4 14:33:02 CDT 2011
Hi Matt!
We deal with this same issue in PyClaw/PetClaw, I think Amal could do a much
better job describing the approach (or copying a relevant section from her
Master's thesis) we take to avoid copying, but the idea is to follow the
native PETSc ordering with interleaved degrees-of-freedom to keep the most
compatibility with the other DA calls.
A
On Mon, Jul 4, 2011 at 10:19 PM, Matthew Emmett <memmett at unc.edu> wrote:
> On Mon, Jul 4, 2011 at 2:52 PM, Lisandro Dalcin <dalcinl at gmail.com> wrote:
> > No, sorry... It has nothing to do with periodicity... It is actually a
> > C/Fortran ordering issue I need to fix...
> Ah, I see. Thanks for looking into this so quickly. Let me know if
> there is anything I can do on my end to help. I will poke around the
> code for petsc4py, but you obviously know it better than I do.
> > In Fortran 90, it seems you index a DA Vec array as A[dof,x,y,z]... ,
> > However, I think that for Python we should follow a more C-ish
> > indexing A[x,y,z,dof]. Or we could do it like PETSc in C, that is
> > A[z,y,x,dof] (wich is the transpose of the Fortran way) but it is
> > counter-intuitive to C (and likely Python) programmers ...
> > What do others think about this?
> I think A[x,y,z,dof] is probably the most intuitive for Python.
> Matt
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110704/cfedcef9/attachment.htm>
