[petsc-users] petsc4py DA with dof>1 confusion
Matthew Emmett memmett at unc.edu
Mon Jul 4 12:25:54 CDT 2011
Hi everyone,
I am trying to use petsc4py in a fairly straight forward finite volume
shallow-water code (the PDE has three unknowns). I have a structured
grid and am using a DA to communicate ghost cells.  When I use dof=1,
everything works as I would expect.  However, when I try to use dof=3,
I am confused by the results.  I have probably mis-understood
something -- any suggestions would be appreciated.
For example (see attached script), first I create the DA ('dof' and
'width' are defined):
  da = PETSc.DA().create(dim=2, sizes=[8, 8], dof=dof,
                         boundary_type='periodic',
                         stencil_width=width,
                         stencil_type='box')
Next, I create global and local vectors:
  gvec = da.createGlobalVec()
  lvec = da.createLocalVector()
Then, put something into the local vectors, and scatter:
  with da.getVecArray(lvec) as va:
    if dof == 1:
      va.array[width:-width,width:-width] = MPI.COMM_WORLD.rank+1
    else:
      va.array[width:-width,width:-width,0] = MPI.COMM_WORLD.rank+1
  da.localToGlobal(lvec, gvec)
Finally, get the local vector again and print:
  da.globalToLocal(gvec, lvec)
    if dof == 1:
      print va.array[:,:]
    else:
      print va.array[:,:,0]
With 'dof=1' I get the following on the second processor:
[[ 1.  2.  2.  2.  2.  1.]
 [ 1.  2.  2.  2.  2.  1.]]
With 'dof=3' I get the following on the second processor:
[[ 0.  0.  0.  0.  0.  0.]
 [ 0.  0.  0.  0.  2.  0.]
 [ 0.  0.  0.  2.  2.  0.]
 [ 0.  0.  0.  2.  2.  2.]
 [ 0.  0.  0.  0.  0.  2.]]
I was expecting to see the same as the 'dof=1' case, since I am
setting (and printing) va.array[:,:,0].
Again, any suggestions would be appreciated.  Thanks,
Matt
PS, thanks to the developers of PETSc and petsc4py for all your hard
work.  I had the pleasure of meeting Jed and Matt at KAUST recently.
Type: text/x-python
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110704/4b63bd71/attachment.py>
