[petsc-users] ILU and Block Gauss Seidel smoothing
Jed Brown
jed at 59A2.org
Fri Jul 1 07:43:33 CDT 2011
On Fri, Jul 1, 2011 at 07:11, Gianluca Meneghello <gianmail at gmail.com>wrote:
> I've tried to implement Jed's solution as it was looking faster to
> try. This is what I came up with for two different orders, FENOrder
> and FWNOrder respectively
> 283 KSP ksp;
> 284 PC pc;
> 285
> 286 ierr = KSPCreate(PETSC_COMM_WORLD,&ksp); CHKERRQ(ierr);
> 287 ierr = KSPSetOptionsPrefix(ksp,"mg_"); CHKERRQ(ierr);
> 288 ierr = KSPSetOperators(ksp,J,J,SAME_NONZERO_PATTERN);
> CHKERRQ(ierr);
> 289 ierr = KSPSetFromOptions(ksp); CHKERRQ(ierr);
> 290 ierr = KSPGetPC(ksp,&pc); CHKERRQ(ierr);
> 291 ierr = PCFactorSetFill(pc,1); CHKERRQ(ierr);
> 292 ierr = PCFactorSetMatOrderingType(pc,"FENOrder"); CHKERRQ(ierr);
> 293 ierr = KSPSolve(ksp,b,x); CHKERRQ(ierr);
> 294 ierr = KSPDestroy(&ksp); CHKERRQ(ierr);
> 295
> 296 ierr = KSPCreate(PETSC_COMM_WORLD,&ksp); CHKERRQ(ierr);
> 297 ierr = KSPSetOptionsPrefix(ksp,"mg_"); CHKERRQ(ierr);
> 298 ierr = KSPSetOperators(ksp,J,J,SAME_NONZERO_PATTERN);
> CHKERRQ(ierr);
> 299 ierr = KSPSetFromOptions(ksp); CHKERRQ(ierr);
> 300 ierr = KSPGetPC(ksp,&pc); CHKERRQ(ierr);
> 301 ierr = PCFactorSetFill(pc,1); CHKERRQ(ierr);
> 302 ierr = PCFactorSetMatOrderingType(pc,"FWNOrder"); CHKERRQ(ierr);
> 303 ierr = KSPSolve(ksp,b,x); CHKERRQ(ierr);
> 304 ierr = KSPDestroy(&ksp); CHKERRQ(ierr);
It looks like you are putting all of this in PCApply_YourShell(). I suggest
making
struct YourShellContext {
PC fenpc,fwnpc;
Vec work;
PetscBool issetup;
Then pass a pointer to this thing in when you create the PCShell. Then
something like
PCSetUp_YourShell(PC pc) {
struct YourShellContext *ctx;
Mat A,B;
MatStructure mstr;
const char *prefix;
char iprefix[256];
PCShellGetContext(pc,&ctx);
PCGetOptionsPrefix(pc,&prefix);
if (!ctx->issetup) {
ierr = MatGetVecs(A,&ctx->work,PETSC_NULL);
PCCreate(comm,&ctx->fenpc);
PCSetType(ctx->fenpc,PCILU);
PCFactorSetFill(ctx->fenpc,1);
PCFactorSetMatOrderingType(ctx->fenpc,"FENOrder");
snprintf(iprefix,sizeof iprefix,"%sfen",prefix);
PCSetOptionsPrefix(ctx->fenpc,iprefix);
PCSetFromOptions(ctx->fenpc);
/* Same as above for ctx->fwnpc */
PCGetOperators(pc,&A,&B,&mstr);
PCSetOperators(ctx->fenpc,A,B,mstr);
PCSetOperators(ctx->fwnpc,A,B,mstr);
PCSetUp(ctx->fenpc);
PCSetUp(ctx->fwnpc);
ctx->issetup = PETSC_TRUE;
Then in PCApply_YourShell(PC pc,Vec X,Vec Y) {
PCGetOperators(pc,&A,PETSC_NULL,PETSC_NULL);
PCApply(ctx->fenpc,X,Y); /* apply first ordering */
VecScale(Y,-1.0);
MatMultAdd(A,Y,X,ctx->work); /* Compute fresh residual */
PCApply(ctx->fwnpc,ctx->work,Y);
> I don't know if this is what you intended... is there a way to make
> KSP recompute the factorization with the different ordering without
> destroying and recreating the KSP?
Store both as in the code above.
> Concerning Barry's option, js it possible to use the PETSc ilu
> factorization function (and eventually the ones provided by external
> libraries) inside my PCSHELL, passing it the various ordering I will
> need? If so, what's the best way to access it?
Does the code above answer this question?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110701/67adb3be/attachment-0001.htm>
