[petsc-users] Using SuperLU_Dist with petsc-3.0.0-p12: Necessary to use -pc_type lu ??
    Matthew Knepley
    knepley at gmail.com
    Tue Jan 25 22:34:01 CST 2011
On Tue, Jan 25, 2011 at 10:13 PM, Gaurish Telang <gaurish108 at gmail.com>wrote:
> Hi I have configured petsc-3.0.0-p12 along with SuperLU_Dist.
> When we use SuperLU as an external solver the manual saya that we must pass
> -pc_factor_mat_solver_package superlu_dist as an option.
> I notice that when we provide -pc_type lu the example runs smoothly. but
> without this option, -log_summary says
> WARNING! There are options you set that were not used!
> WARNING! could be spelling mistake, etc!
> Option left: name:-pc_factor_mat_solver_package value: superlu_dist
> Does this mean -pc_type lu must always be provided as an option when using
> SuperLU_Dist????
You must tell the PC to do LU factorization in order for the solver package
to be meaningful. One
way to do that is -pc_type lu.
> Also there was a bug when using SuperLU_Dist along with -ksp_view in
> petsc-3.1p5. I dont have the same problem when using petsc-3.0.0-p12 . Are
> there any reported problems when using petsc-3.0.0p12
> with SuperLU_Dist
None that I know of.
  Matt
> Gaurish
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110125/be2fdb43/attachment.htm>
