[petsc-users] Out of memory during MatAssemblyBegin
    Raeth, Peter
    PRaeth at hpti.com
    Mon Jan 24 15:08:25 CST 2011
Am running out of memory while using MatAssemblyBegin on a dense matrix that spans several processors. My calculations show that the matrices I am using do not require more than 25% of available memory.
Different about this matrix compared to the others is that the program runs out of memory after the matrix has been populated by a single process, rather than by multiple processes. Used MatSetValues. Since the values are held in cache until MatAssemblyEnd is called (as I understand things), is it possible that using one process to populate the entire matrix is causing this problem? The data is brought in only row by row for the population process. All buffer memory is cleared before the call to MatAssemblyBegin.
The error dump contains:
mpirun -prefix [%g]   -np 256 Peter.x
[0]  [0]PETSC ERROR: --------------------- Error Message ------------------------------------
[0]  [0]PETSC ERROR: Out of memory. This could be due to allocating
[0]  [0]PETSC ERROR: too large an object or bleeding by not properly
[0]  [0]PETSC ERROR: destroying unneeded objects.
[0]  [0]PETSC ERROR: Memory allocated 1372407920 Memory used by process -122585088
[0]  [0]PETSC ERROR: Try running with -malloc_dump or -malloc_log for info.
[0]  [0]PETSC ERROR: Memory requested 18446744071829395456!
[0]  [0]PETSC ERROR: ------------------------------------------------------------------------
[0]  [0]PETSC ERROR: Petsc Release Version 3.1.0, Patch 6, Tue Nov 16 17:02:32 CST 2010
[0]  [0]PETSC ERROR: See docs/changes/index.html for recent updates.
[0]  [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[0]  [0]PETSC ERROR: See docs/index.html for manual pages.
[0]  [0]PETSC ERROR: Peter.x on a linux-int named hawk-6 by praeth Mon Jan 24 15:44:28 2011
[0]  [0]PETSC ERROR: Libraries linked from /default/praeth/MATH/petsc-3.1-p6/linux-intel-g/lib
[0]  [0]PETSC ERROR: Configure run at Tue Dec 21 08:45:25 2010
[0]  [0]PETSC ERROR: Configure options --download-superlu=1 --download-parmetis=1 --download-superlu_dist=1 --with-debugging=1 --with-error-checking=1 -PETSC_ARCH=linux-intel-g --with-fc="ifort -lmpi" --with-cc="icc -lmpi" --with-gnu-compilers=false
[0]  [0]PETSC ERROR: PetscMallocAlign() line 49 in src/sys/memory/mal.c
[0]  [0]PETSC ERROR: PetscTrMallocDefault() line 192 in src/sys/memory/mtr.c
[0]  [0]PETSC ERROR: MatStashScatterBegin_Private() line 510 in src/mat/utils/matstash.c
[0]  [0]PETSC ERROR: MatAssemblyBegin_MPIDense() line 286 in src/mat/impls/dense/mpi/mpidense.c
[0]  [0]PETSC ERROR: MatAssemblyBegin() line 4564 in src/mat/interface/matrix.c
[0]  [0]PETSC ERROR: User provided function() line 195 in "unknowndirectory/"Peter.c
[-1]  MPI: MPI_COMM_WORLD rank 0 has terminated without calling MPI_Finalize()
[-1]  MPI: aborting job
exit
Had tried to use the suggestion to employ -malloc_dump or -malloc_log but do not see any result from the batch run.
Thank you all for any insights you can offer.
Best,
Peter.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110124/12b71fd6/attachment.htm>
