[petsc-users] 2 levels of parallelism for ASM
DUFAUD THOMAS thomas.dufaud at univ-lyon1.fr
Mon Jan 24 08:09:03 CST 2011
I noticed that the local solution of an ASM preconditioner is performed on a single processor per domain, usually setting a KSP PREONLY to perform an ILU factorization.
I would like to perform those local solution with a krylov method (GMRES) among a set of processors.
Is it possible, for an ASM preconditioner, to set a subgroup of processors per domain and then define parallel sub-solver over a sub-communicator?
If it is the case how can I manage operation such as MatIncreaseOverlap?
If it is not the case, does it exist a way to do that in PETSc?
Thomas
