[petsc-users] Using KSPLSQR without explicitly computing U(transpose)U
Gaurish Telang gaurish108 at gmail.com
Sun Jan 23 00:39:18 CST 2011
I have been trying to solve an overdetermined system of linear equations on
PETSc using KSPLSQR.
Now for my minimization problem |Ux-b| where U has dimension 2683x1274, U
has full rank but is badly conditioned. This makes the algorithm LSQR an
ideal algorithm for doing Least sqaures here, (at least according to the
paper by Paige and Saunders.)
I have been able to solve the normal equations ,
U(transpose)Ux=U(transpose)b successfully with KSPLSQR, in the usual way one
solves linear systems with SQUARE matrices.
But for this I had to compute U(transpose)U explicitly. The algorithm
mentioned in the paper does NOT involve an explicit computation of
U(transpose)U.
Is there a way to avoid the explicit and expensive computation of
U(transpose)U and use KSPLSQR?  The details on this page
http://www.mcs.anl.gov/petsc/petsc-2/snapshots/petsc-current/docs/manualpages/KSP/KSPLSQR.htmldid
not really help.
I have also experimented with the suggesstions in the thread
http://lists.mcs.anl.gov/pipermail/petsc-users/2010-August/006784.html but I
kept getting errors saying there is a dimension mismatch
I use KSPSetOperators as ierr =
KSPSetOperators(ksp,Prod,Prod,SAME_PRECONDITIONER);CHKERRQ(ierr); where
Prod=U(Transpose)U calculated in the previous statements.
Anyway, I am providing my current working code underneath just for
reference.  U and b are provided through files.
I am guessing the answer lies in the way one uses KSPSetOperators but I am
not sure.
Gaurish Telang
static char help[] = " Doing least squares   \n\
  -f <input_file> : file to load \n\n";
  Include "petscmat.h" so that we can use matrices.
  automatically includes:
     petscsys.h       - base PETSc routines   petscvec.h    - vectors
     petscmat.h    - matrices
     petscis.h     - index sets            petscviewer.h -
viewers
#include "petscmat.h"
#include "petscvec.h"
#include "petscksp.h"        /* For the iterative solvers */
#include <stdlib.h>
#include <stdio.h>
#undef __FUNCT__
#define __FUNCT__ "main"
int main(int argc,char **args)
  Mat                   U,U_Transpose,Prod;                /* matrix */
  PetscViewer           fd;               /* viewer */
  char                  file[PETSC_MAX_PATH_LEN];     /* input file name */
  PetscErrorCode        ierr;
  PetscTruth            flg;
  Vec                   b,x,new_rhs;
  PetscInt              i,n,m,bsize=2683,index; /* bsize indicates the text
file size of bx.mat */
  PetscScalar           *xx;
  PetscScalar rhs[bsize];
  FILE *fp;
  KSP ksp;
  PC pc;
  PetscMPIInt size;
PetscInt num_iters;
PetscReal rnorm;
KSPConvergedReason reason;
  PetscInitialize(&argc,&args,(char *)0,help);
  ierr =
PetscOptionsGetString(PETSC_NULL,"-f",file,PETSC_MAX_PATH_LEN-1,&flg);CHKERRQ(ierr);
  if (!flg) SETERRQ(1,"Must indicate binary file with the -f option");
  ierr =
PetscViewerBinaryOpen(PETSC_COMM_WORLD,file,FILE_MODE_READ,&fd);CHKERRQ(ierr);
  ierr = MatLoad(fd,MATMPIAIJ,&U);CHKERRQ(ierr);
  ierr = PetscViewerDestroy(fd);CHKERRQ(ierr);
  ierr = MatGetSize(U,&m,&n);CHKERRQ(ierr);
  PetscPrintf(PETSC_COMM_WORLD,"# matrix Rows=%i and # matrix Columns=%i
\n\n\n",m,n);
  PetscPrintf(PETSC_COMM_WORLD,"The matrix is \n\n");
  // ierr=MatView(U,PETSC_VIEWER_STDOUT_WORLD);CHKERRQ(ierr);
  ierr=VecCreateMPI(PETSC_COMM_WORLD,PETSC_DECIDE,bsize,&b);CHKERRQ(ierr);
  ierr = VecSet(b,0);CHKERRQ(ierr);
  /* Reading in the RHS vector. */
fp=fopen("b1.mat","r");
if (fp==NULL)
     fprintf(stderr, "Cannot open file");
     exit(1);
    for (i = 0; i < bsize; i++)
           if (fscanf(fp,"%lf", &rhs[i]) != 1)
                fprintf(stderr, "Failed to read rhs vector[%d]\n", i);
                exit(1);
    index=0;
/*Putting b into final form */
for (i=0; i<bsize; ++i)
    ierr= VecSetValues(b,1,&index,&rhs[i],INSERT_VALUES);CHKERRQ(ierr); /*
One insertion per step. Thats what the 1 in second argument stands for */
    index=index+1;
/* The third and fourth arguments are addresses. The fifth argument is IORA
     /* Assembling the vector.  */
    ierr= VecAssemblyBegin(b);CHKERRQ(ierr);
    ierr=VecAssemblyEnd(b);CHKERRQ(ierr);
     /* Viewing the rhs vector.  */
    ierr=PetscPrintf(PETSC_COMM_WORLD,"Vector b:\n");CHKERRQ(ierr);
    // ierr=VecView(b,PETSC_VIEWER_STDOUT_WORLD);CHKERRQ(ierr);
  /* Creating the solution vector x and the new_rhs vector of size n.--->>
  ierr = VecCreateMPI(PETSC_COMM_WORLD,PETSC_DECIDE,n,&x);CHKERRQ(ierr);
ierr = VecCreateMPI(PETSC_COMM_WORLD,PETSC_DECIDE,n,&new_rhs);CHKERRQ(ierr);
  /* Creating the U_transpose matrix and actually seting the values in it */
  ierr=MatTranspose(U, MAT_INITIAL_MATRIX,&U_Transpose);CHKERRQ(ierr);
  ierr=PetscPrintf(PETSC_COMM_WORLD,"\n \n U Transpose:\n\n");CHKERRQ(ierr);
  //  ierr=MatView(U_Transpose,PETSC_VIEWER_STDOUT_WORLD);CHKERRQ(ierr);
  /* Creating the matrix Prod and setting it to U_transpose*U  */
ierr=MatMatMult(U_Transpose,U,MAT_INITIAL_MATRIX,PETSC_DEFAULT,&Prod);CHKERRQ(ierr);
  ierr=PetscPrintf(PETSC_COMM_WORLD,"\n\n Product Ut *U:\n");CHKERRQ(ierr);
  // ierr=MatView(Prod,PETSC_VIEWER_STDOUT_WORLD);CHKERRQ(ierr);
  /* Creating the matrix-vec product */
  ierr=MatMult(U_Transpose,b,new_rhs);CHKERRQ(ierr);
  ierr=PetscPrintf(PETSC_COMM_WORLD,"\n\n new rhs:\n");CHKERRQ(ierr);
  // ierr=VecView(new_rhs,PETSC_VIEWER_STDOUT_WORLD);CHKERRQ(ierr);
  ierr = KSPCreate(PETSC_COMM_WORLD,&ksp);CHKERRQ(ierr);
     Set operators. Here the matrix that defines the linear system
     also serves as the preconditioning matrix.
  ierr = KSPSetOperators(ksp,Prod,Prod,SAME_PRECONDITIONER);CHKERRQ(ierr);
  ierr = KSPGetPC(ksp,&pc);CHKERRQ(ierr);
    ierr = PCSetType(pc,PCJACOBI);CHKERRQ(ierr);
  ierr =
KSPSetTolerances(ksp,1.e-6,PETSC_DEFAULT,PETSC_DEFAULT,PETSC_DEFAULT);CHKERRQ(ierr);
    Set runtime options, e.g.,
        -ksp_type <type> -pc_type <type> -ksp_monitor -ksp_rtol <rtol>
    These options will override those specified above as long as
    KSPSetFromOptions() is called _after_ any other customization
    routines.
  ierr = KSPSetFromOptions(ksp);CHKERRQ(ierr);
  ierr = KSPSolve(ksp,new_rhs,x);CHKERRQ(ierr);
  ierr = KSPView(ksp,PETSC_VIEWER_STDOUT_WORLD);CHKERRQ(ierr);
   ierr=VecView(x,PETSC_VIEWER_STDOUT_WORLD);CHKERRQ(ierr);
  ierr = MatDestroy(U);CHKERRQ(ierr);
  ierr = MatDestroy(U_Transpose);CHKERRQ(ierr);
  ierr = MatDestroy(Prod);CHKERRQ(ierr);
  ierr = VecDestroy(b);CHKERRQ(ierr);
  ierr=  VecDestroy(x);CHKERRQ(ierr);
  ierr=  VecDestroy(new_rhs);CHKERRQ(ierr);
ierr = PetscFinalize();CHKERRQ(ierr);
  return 0;
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110123/ed28e0af/attachment.htm>
