[petsc-users] Makefile on Photran with PETSc in linux
    Satish Balay
    balay at mcs.anl.gov
    Wed Jan 19 08:47:52 CST 2011
you shouldn't start a new thread by replying to previous threads.
It messes up threaded e-mail readers.
On Wed, 19 Jan 2011, TAY wee-beng wrote:
> Hi,
> I can compile with PETSc on linux with the makefile provided by the PETSc
> team. I'm now trying to use photran. I have made a makefile which is very
> basic and it basically list out all the commands to run. It can be used to
> compile on photran.
> However, I hope to use the makefile provided by the PETSc team because it is
> much more flexible. However when I use it, it says:
> **** Build of configuration Default for project ibm2d_high_Re ****
> make all
> make: *** No rule to make target `all'.  Stop.
ALL: a.out
I guess you've typed in 'ALL' instead of 'all'
Satish
> I have attached the 2 makefiles:
> Makefile - from PETSc team
> Makefile_old - my own makefile
> Yours sincerely,
> TAY wee-beng
