[petsc-users] loading a matrix in PETSc : Problems
    Gaurish Telang
    gaurish108 at gmail.com
    Sun Jan 16 15:21:15 CST 2011
Given matrix A and column vector b. I am trying to do a Least squares
problem Ax=b on PETSc.
A has dimenstion 2683x1274
I have A given to me in a text file in the form of three columns (Row,
Column,NonZeroElement).
E.g. If a matrix of dimension 2x3  such as
0 5 3
5 6 0
 would be given in the text file as:
1 2 5
1 3 3
2 1 5
2 2 6
The third column just lists the non-zero elements and the corresponding
first two columsn the position,.
Now I am trying to input this textfile data into  PETSc matrix A. But my
matrix takes forever to load.
The same code on small matrices of dimension say 4x3 works perfectly.
I have pasted my PETSc code below. Any suggestions on improving it will be
helpful.
***Explanation of my code****:
For my code I start with two text files: N1.mat and b1.mat---->
N1.mat containing the matrix A in (Row,Column,Nonzeroelement)  format and
b1.mat containing the right hand side b.
Then I read in the three columns of N1.mat as a matrix B which  I use to
re-create the matrix A. The dimension of B is lenB x 3 where lenB is the
number of lines in the text file containing B(39051 in my case).
b1.mat gets read in directly as a the vector b.
static char help[]="Reading in a matrix\n";
#include<stdio.h>
#include<math.h>
#include<stdlib.h>
#include "petscvec.h" /* This enables us to use vectors. */
#include "petscmat.h" /* This enables us to use Matrices. It includes the
petscvec header file*/
#include "petscksp.h" /* Now we can solve linear systems. Solvers used are
KSP. */
int main(int argc, char **argv)
/* Declaration of Matrix A and some vectors x*/
Vec b;
int tempi,tempj;
Mat A;
FILE *fp;
MPI_Comm comm;
PetscInt n=2683,m=1274,index,lenB=39051;
PetscScalar scalar,rhs[n],B[lenB][3];
PetscErrorCode ierr;
PetscInt i,j;
comm = MPI_COMM_SELF;
/* This part is needed for the help flag supplied at run-time*/
ierr = PetscInitialize(&argc,&argv,(char*)0,help);CHKERRQ(ierr);
ierr = PetscOptionsGetInt(PETSC_NULL,"-n",&n,PETSC_NULL);CHKERRQ(ierr);
/* Use options from the terminal to create a vector that is type shared or
mpi. */
ierr = VecCreate(PETSC_COMM_WORLD,&b);CHKERRQ(ierr); /* Vector creation */
ierr = VecSetSizes(b,PETSC_DECIDE,n);CHKERRQ(ierr); /* Setting the vector
size */
ierr = VecSetFromOptions(b);CHKERRQ(ierr); /* Setting the vector type
(shared, mpi etc) */
/* The second argument is a PETSc scalar value.*/
ierr = VecSet(b,0);CHKERRQ(ierr);
/* Reading in the RHS vector. */
/* Reading in the matrix from the file matrix.txt */
fp=fopen("b1.mat","r");
if (fp==NULL)
fprintf(stderr, "Cannot open file");
exit(1);
for (i = 0; i < n; i++)
if (fscanf(fp,"%lf", &rhs[i]) != 1)
fprintf(stderr, "Failed to read rhs vector[%d]\n", i);
exit(1);
index=0;
/*Putting x into final form */
for (i=0; i<n; ++i)
ierr= VecSetValues(b,1,&index,&rhs[i],INSERT_VALUES);CHKERRQ(ierr); /* One
insertion per step. Thats what the 1 in second argument stands for */
index=index+1;
} /* The third and fourth arguments are addresses. The fifth argument is
IORA */
/* Assembling the vector. */
ierr= VecAssemblyBegin(b);CHKERRQ(ierr);
ierr=VecAssemblyEnd(b);CHKERRQ(ierr);
/* Viewing the changed vector. */
ierr=PetscPrintf(PETSC_COMM_WORLD,"Vector b:\n");CHKERRQ(ierr);
ierr=VecView(b,PETSC_VIEWER_STDOUT_WORLD);CHKERRQ(ierr);
ierr=MatCreate(PETSC_COMM_WORLD,&A);CHKERRQ(ierr);
ierr = MatSetSizes(A,n,m,n,m);CHKERRQ(ierr); /* Setting the matrix size */
ierr = MatSetFromOptions(A);CHKERRQ(ierr); /* Setting the matrix type
fp=fopen("N1.mat","r");
if (fp==NULL)
exit(1);
for (i = 0; i < lenB; i++)
for (j = 0; j < 3; j++)
if (fscanf(fp,"%lf", &B[i][j]) != 1)
fprintf(stderr, "Failed to read matrix[%d][%d]\n", i, j);
exit(1);
/* Initializing the matrix A to zero matrix */
for(i=0;i<n;++i)
for(j=0;j<m;++j)
scalar=0.0;
ierr=MatSetValues(A,1,&i,1,&j,&scalar,INSERT_VALUES);CHKERRQ(ierr);
ierr=MatAssemblyBegin(A,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
ierr=MatAssemblyEnd(A,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
/* Inserting the non-zero elements. */
for(i=0;i<lenB;++i)
tempi=(int)B[i][0]-1;
tempj=(int)B[i][1]-1;
ierr=MatSetValues(A,1,&tempi,1,&tempj,&B[i][2],INSERT_VALUES);CHKERRQ(ierr);
//ierr=MatView(A,PETSC_VIEWER_STDOUT_WORLD);CHKERRQ(ierr);
Destroy any objects created.
ierr=VecDestroy(b);CHKERRQ(ierr);
ierr=MatDestroy(A);CHKERRQ(ierr);
ierr=PetscFinalize();CHKERRQ(ierr);
return 0;
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110116/f0c62de9/attachment.htm>
