[petsc-users] unstructured parallel
    Hong Zhang
    hzhang at mcs.anl.gov
    Fri Jan 14 16:32:18 CST 2011
Sorry, I mean
> They solve same problem, but illustrate different TS solvers and approaches.
> Although ex4.c uses DA in main() to create vectors and is intended to
> illustrate a non-linear TS solver,
> its function evaluation does use DA. ex4.c is not a good example for using DA.
                                    dose NOT use DA.
Hong
> Almost all petsc objects and solvers are parallel, which manage
> parallel data distribution and implementation.
> DA is one of objects.
> Hong
>> At last is there any example I can learn to get a parallel version of my
>> problem.
>> Thanks!
