[petsc-users] Questions about PETSc
Zuhair Khayyat
zuhair.khayyat at kaust.edu.sa
Sun Jan 9 01:45:34 CST 2011
Dear Aron,
Actually the file is an output of another application, and is stored in a
simple text file. I have read about MPIIO, however couldn't figure out if it
is a parallel file reader or not.
Have you ever tried or worked on a parallel file reader to a common global
matrix in PETSc, where each processor has part of the file? Thank you
Zuhair Khayyat
On Sat, Jan 8, 2011 at 8:42 PM, Aron Ahmadia <aron.ahmadia at kaust.edu.sa>wrote:
> if the file is stored in the PETSc format, you can use PETSc to pull the
> file in using MPIIO, which should be (hopefully) faster.
> http://www.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-current/docs/manualpages/Viewer/PetscViewerBinarySetMPIIO.html
> Feel free to pop these questions to petsc-users (cc'd), there are more of
> them and they usually know more than me :)
> -Aron
> On Sat, Jan 8, 2011 at 2:21 PM, Zuhair Khayyat <
> zuhair.khayyat at kaust.edu.sa> wrote:
>> Dear Aron,
>> Currently I am using PETSc for my research to implement a graph mining
>> algorithm on a large cluster, and I would like ask you some questions due to
>> your experience with this tool.
>> Have you ever tried to optimize allocating a very large matrix from input
>> file in parallel? I have a very large file (around 10 GB) and it takes too
>> long to allocate the matrix through the main node. I am planning to
>> implement a distributed parallel file reader that split the original file
>> and make each node reads it separately into a common matrix.
>> Is there and other tools that are comparable to PETSc in which they have
>> parallel file reader?
>> Thank you for your help
>> Regards,
>> Zuhair Khayyat
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110109/84955856/attachment.htm>
