[petsc-users] Questions about PETSc
Aron Ahmadia aron.ahmadia at kaust.edu.sa
Sat Jan 8 11:42:02 CST 2011
if the file is stored in the PETSc format, you can use PETSc to pull the
file in using MPIIO, which should be (hopefully) faster.
http://www.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-current/docs/manualpages/Viewer/PetscViewerBinarySetMPIIO.html
Feel free to pop these questions to petsc-users (cc'd), there are more of
them and they usually know more than me :)
-Aron
On Sat, Jan 8, 2011 at 2:21 PM, Zuhair Khayyat
<zuhair.khayyat at kaust.edu.sa>wrote:
> Dear Aron,
> Currently I am using PETSc for my research to implement a graph mining
> algorithm on a large cluster, and I would like ask you some questions due to
> your experience with this tool.
> Have you ever tried to optimize allocating a very large matrix from input
> file in parallel? I have a very large file (around 10 GB) and it takes too
> long to allocate the matrix through the main node. I am planning to
> implement a distributed parallel file reader that split the original file
> and make each node reads it separately into a common matrix.
> Is there and other tools that are comparable to PETSc in which they have
> parallel file reader?
> Thank you for your help
> Regards,
> Zuhair Khayyat
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110108/fa0c2ef2/attachment.htm>
