[petsc-users] [petsc-dev] configure option missing for MPI.h / on IBM machine
Aron Ahmadia
aron.ahmadia at kaust.edu.sa
Thu Feb 10 07:44:09 CST 2011
add opt/ibmhpc/ppe.poe/include/ibmmpi/ to your ./configure options like
this:
--with-mpi-include=/opt/ibmhpc/ppe.poe/include/ibmmpi/
You may have to manually add the MPI libraries and their path as well, since
BuildSystem tends to like these packaged together. Ping the list back if
you can't figure it out from there.
-Aron
On Thu, Feb 10, 2011 at 3:23 PM, lvankampenhout at gmail.com <
lvankampenhout at gmail.com> wrote:
> Hi all, i'm having this error when configuring the latest petsc-dev on an
> IBM PPC system.
> TESTING: CxxMPICheck from
> config.packages.MPI(/gpfs/h01/vkampenh/install/petsc-dev/config/BuildSystem/config/packages/MPI.py:611)
> UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log for
> details):
> C++ error! mpi.h could not be located at: []
> My configure options: ./configure --with-batch=1 --with-mpi-shared=0
> --with-endian=big --with-memcmp-ok --sizeof-void-p=8 --sizeof-char=1
> --sizeof-short=2 --sizeof-int=4 --sizeof-long=8 --sizeof-size-t=8
> --sizeof-long-long=8 --sizeof-float=4 --sizeof-double=8 --bits-per-byte=8
> --sizeof-MPI-Comm=8 --sizeof-MPI-Fint=4 --have-mpi-long-double=1
> --with-f90-interface=rs6000 --with-cc="mpcc -compiler xlc_r -q64"
> --with-fc="mpfort -compiler xlf_r -q64" --FFLAGS="-O3 -qhot -qstrict
> -qarch=auto -qtune=auto" --CFLAGS="-O3 -qhot -qstrict -qarch=auto
> -qtune=auto" --LIBS=-lmass_64 --with-ar=/usr/bin/ar
> --prefix=/sara/sw/petsc/3.0.0-p8/real --with-scalar-type=real
> PETSC_ARCH=linux-ibm-pwr6-xlf-real-64 --with-shared=0 -with-debugging=0
> --download-ml --download-hypre
> vkampenh at p6012:~/install/petsc-dev> module list
> Currently Loaded Modulefiles:
> 1) compilerwrappers/yes 4) c++/ibm/11.1 7) upc/ibm/11.1
> 2) java/ibm/1.5 5) fortran/ibm/13.1
> 3) c/ibm/11.1 6) sara
> vkampenh at p6012:~/install/petsc-dev> locate mpi.h
> /opt/ibm/java2-ppc64-50/include/jvmpi.h
> /opt/ibmhpc/ppe.poe/include/ibmmpi/mpi.h
> /opt/mpich/include/mpi.h
> /usr/include/boost/mpi.hpp
> /usr/lib64/gcc/powerpc64-suse-linux/4.3/include/jvmpi.h
> /usr/lib64/mpi/gcc/openmpi/include/mpi.h
> /usr/lib64/mpi/gcc/openmpi/include/openmpi/ompi/mpi/f77/prototypes_mpi.h
> /usr/src/linux-2.6.32.27-0.2-obj/ppc64/default/include/config/usb/serial/siemens/mpi.h
> /usr/src/linux-2.6.32.27-0.2-obj/ppc64/ppc64/include/config/usb/serial/siemens/mpi.h
> /usr/src/linux-2.6.32.27-0.2-obj/ppc64/trace/include/config/usb/serial/siemens/mpi.h
> /usr/src/linux-2.6.32.27-0.2/drivers/message/fusion/lsi/mpi.h
> Is there an easy way to add the IBMHPC/PPE.POE directory to the configure
> list, so that it will be recognized? The machine uses LoadLeveler schedule
> system, which handles the MPI settings.
> Thanks,
> Leo
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110210/06a897d5/attachment.htm>
