[petsc-users] debugging with no X11 available
Dominik Szczerba dominik at itis.ethz.ch
Mon Dec 12 09:15:51 CST 2011
> As several others suggested, you can probably do this on your own laptop or
> workstation if you can reproduce the problem locally.  This is how I debug
> all of my parallel code.
The problem is there is no problem on my own machine... only there :`(
OK, giving up, probably I need to either learn their debugger or debug
by foot, commenting out single code lines and adding verbosity....
Many thanks and best regards,
Dominik
