[petsc-users] debugging with no X11 available
Aron Ahmadia
aron.ahmadia at kaust.edu.sa
Mon Dec 12 08:19:43 CST 2011
> It would be very helpful to be able to run 2 processes in a debugger
> without relying on X11 at all...
As several others suggested, you can probably do this on your own laptop or
workstation if you can reproduce the problem locally. This is how I debug
all of my parallel code.
A
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111212/1350fb19/attachment.htm>
