[petsc-users] debugging with no X11 available
Aron Ahmadia
aron.ahmadia at kaust.edu.sa
Mon Dec 12 06:52:54 CST 2011
Sorry, to expand my answer, "what Matt said". You don't have the advantage
of using the functionality of -start_in_debugger if you cannot make X11
connections from the compute nodes, so you will need to rely on whatever
debugging facilities your systems team has set up, and break on PetscError
if you want to catch PETSc errors percolating up the stack.
A
On Mon, Dec 12, 2011 at 3:48 PM, Aron Ahmadia <aron.ahmadia at kaust.edu.sa>wrote:
> Not on a BG/P you can't.
> A
> On Mon, Dec 12, 2011 at 3:46 PM, Matthew Knepley <knepley at gmail.com>wrote:
>> On Mon, Dec 12, 2011 at 2:48 AM, Dominik Szczerba <dominik at itis.ethz.ch>wrote:
>>> Hi,
>>> I am debugging my code on a system that does not allow any X11
>>> connections, therefore the following does not work:
>>> mpiexec -n 2 solver run.xml -start_in_debugger -display :0.0
>>> Are there alternative ways of using a debugger circumventing X11
>>> connections?
>> No. You can usually set the DISPLAY correctly for the backend machine.
>> Consult the admin.
>> Matt
>>> Thanks
>>> Dominik
>> experiments lead.
>> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111212/30920219/attachment.htm>
