[petsc-users] debugging with no X11 available
Aron Ahmadia aron.ahmadia at kaust.edu.sa
Mon Dec 12 06:48:59 CST 2011
Not on a BG/P you can't.
A
On Mon, Dec 12, 2011 at 3:46 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, Dec 12, 2011 at 2:48 AM, Dominik Szczerba <dominik at itis.ethz.ch>wrote:
>> Hi,
>> I am debugging my code on a system that does not allow any X11
>> connections, therefore the following does not work:
>> mpiexec -n 2 solver run.xml -start_in_debugger -display :0.0
>> Are there alternative ways of using a debugger circumventing X11
>> connections?
> No. You can usually set the DISPLAY correctly for the backend machine.
> Consult the admin.
>    Matt
>> Thanks
>> Dominik
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111212/d691d79d/attachment.htm>
