[petsc-users] several messages
Satish Balay
balay at mcs.anl.gov
Wed Dec 7 12:57:36 CST 2011
/opt/petsc/petsc-3.2-p5/mpi_cScalar/include/petscconfiginfo.h(3): error: missing closing quote
Can you send in this file as attachment?
Configure Options: --configModules=PETSc.Configure --optionsModule=PETSc.compilerOptions --with-petsc-arch=mpi_cScalar --with-mpi-dir=/opt/mpich2-current --with-scalar-type=complex --with-blas-lapack-dir=/opt/intel/lib/intel64 --download-umfpack=1 --with-exodusii-dir=/opt/exodusii-4.98 --with-netcdf-dir=/opt/netcdf_v4.1.1 --download-superlu_dist=1 --download-parmetis=1 --download-mumps=1 --download-scalapack=1 --download-blacs=1^M
Not sure how the ^M char crept into the configure run - but perhaps
its causing the petscconfiginfo.h file to be not created correctly.
Satish
On Wed, 7 Dec 2011, Dharmendar Reddy wrote:
> Hello,
> Can you tell me what should be the config options to use the
> scalapack and blacs provided in intel mkl with petsc ?
> thanks
> Reddy
On Wed, 7 Dec 2011, Alexander Grayver wrote:
> Hi Reddy,
> You should use --with-scalapack-lib/include and --with-blacs-lib/include
> For instance:
> --with-scalapack-lib=/opt/intel/Compiler/11.1/072/mkl/lib/em64t/libmkl_scalapack_lp64.a
> --with-scalapack-include=/opt/intel/Compiler/11.1/072/mkl/include
> --with-blacs-lib=/opt/intel/Compiler/11.1/072/mkl/lib/em64t/libmkl_blacs_openmpi_lp64.a
> --with-blacs-include=/opt/intel/Compiler/11.1/072/mkl/include
> Regards,
> Alexander
> On 07.12.2011 13:26, Dharmendar Reddy wrote:
> > Hello,
> > thanks
> > Reddy
> > Dharmendar Reddy Palle
> > Graduate Student
> > Microelectronics Research center,
> > University of Texas at Austin,
> > 10100 Burnet Road, Bldg. 160
> > MER 2.608F, TX 78758-4445
> > e-mail: dharmareddy84 at gmail.com <mailto:dharmareddy84 at gmail.com>
> > Phone: +1-512-350-9082
> > United States of America.
> I sent this email to petsc-users, it bounced back. Can someone please
> clarify the following query..
> ---------- Forwarded message ----------
> From: Dharmendar Reddy <dharmareddy84 at gmail.com>
> Date: Wed, Dec 7, 2011 at 7:42 AM
> Subject: Re: [petsc-users] petsc with scalapack and blacs from intel ?
> To: PETSc users list <petsc-users at mcs.anl.gov>
> I tried --with-scalapack-dir=/opt/inte/mkl/ --with-blacs-dir=/opt/intel/mkl
> and now with the method suggested by you
> I am getting an error. I have attached the configure.log
> UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log for
> details):
> --with-blacs-lib=['/opt/intel/mkl/lib/intel64/libmkl_blacs_openmpi_lp64.a']
> and
> --with-blacs-include=['/opt/intel/mkl/include'] did not work
> On Wed, Dec 7, 2011 at 6:42 AM, Alexander Grayver
> <agrayver at gfz-potsdam.de>wrote:
> > Hi Reddy,
> > For instance:
> > Regards,
> > Alexander
> > Hello,
> > thanks
> > Reddy
> > Graduate Student
> I guess thats incompatible with /opt/intel/mkl/lib/intel64/libmkl_blacs_openmpi_lp64.a
> its easier just to use --download-blacs --download-scalapack.
> Satish
> > details):
> > and
> > > Hi Reddy,
> > > For instance:
> > > Regards,
> > > Alexander
> > > Hello,
> > > thanks
> > > Reddy
> > > Graduate Student
> I was trying to install mumps and then i got messages that i need to
> install scalapack and blacs. I will try the --download options..
> On Wed, Dec 7, 2011 at 10:57 AM, Satish Balay <petsc-maint at mcs.anl.gov>wrote:
> > Satish
> > > details):
> > > and
> > > > Hi Reddy,
> > > > For instance:
> > > > Regards,
> > > > Alexander
> > > > Hello,
> > > > thanks
> > > > Reddy
> > > > Graduate Student
> blacs is dependent on mpi - so if using libmkl_blacs_openmpi_lp64.a -
> make sure you use the right version of openmpi - thats compatible with
> it. [if not - choose the appropriate variant of blacs for your mpi]
> BTW: PETSc does not use blas/scalapack - its primarily needed by mumps.
> Satish
> > Hi Reddy,
> > For instance:
> > Regards,
> > Alexander
> > > Hello,
> > > thanks
> > > Reddy
> > > Graduate Student
> I could configure with download options but now i get make error. Can you
> help me with this..
> On Wed, Dec 7, 2011 at 11:06 AM, Dharmendar Reddy
> >> Satish
> >> for
> >> > details):
> >> > and
> >> > > Hi Reddy,
> >> > > For instance:
> >> > > Regards,
> >> > > Alexander
> >> > > Hello,
> >> > > thanks
> >> > > Reddy
> >> > > Graduate Student
> > Graduate Student
