[petsc-users] MUMPS solver crash with petsc-3.2
Hong Zhang
hzhang at mcs.anl.gov
Wed Dec 7 08:22:18 CST 2011
On Wed, Dec 7, 2011 at 2:53 AM, Gong Ding <gdiso at ustc.edu> wrote:
> I remove #define PETSCHAVE_DEBUG in the petscconf.h, and the debug version runs.
> The dbx report is:
> Segmentation fault in dmumps_462 at line 6743 in file "dmumps_part4.F"
> 6743 IF(DIM.EQ.1) THEN
This crashes inside mumps solver.
Can you install mumps on this machine and run a stand-alone mumps example,
e.g., ~mumps/examples/c_example.c?
Hong
> (dbx) where
> dmumps_462(internal error: assertion failed at line 3650 in file frame.c
> ??, internal error: assertion failed at line 3650 in file frame.c
> ??), line 6743 in "dmumps_part4.F"
>> On Tue, Dec 6, 2011 at 10:54 PM, Gong Ding <gdiso at ustc.edu> wrote:
>> > I can only analysis the core file at present.
>> > It reported
>> > Program terminated with signal 11, Segmentation fault.
>> > #0 0x000000010217319c in dmumps_462 ()
>> > Run program with -info, the output is
>> > Entering DMUMPS driver with JOB, N, NZ = 1 49 217
>> > DMUMPS 4.10.0
>> > L U Solver for unsymmetric matrices
>> > Type of parallelism: Working host
>> > ****** ANALYSIS STEP ********
>> > Resetting candidate strategy to 0 because NSLAVES=1
>> > ... Structural symmetry (in percent)= 100
>> > Density: NBdense, Average, Median = 0 3 3
>> > ... No column permutation
>> > Ordering based on AMF
>> > Program terminated with signal SIGSEGV, Segmentation fault.
>> > The example in src/ksp/ksp/examples/tests/ex3 run ok -- it solves a small
>> > linear problem.
>> > Also, if I reduce the matrix size to ~20x20, no crash happen.
>> > I'll try to provide more information.
>> > On Tue, Dec 6, 2011 at 12:52 AM, Gong Ding <gdiso at ustc.edu> wrote:
>> >> Bad news.
>> >> MUMPS still crash on AIX/PPC.
>> >> I tried petsc-3.1, 3.2 and dev. All of them crash with ERROR: 0031-250
>> >> task 0: Segmentation fault.
>> >> I guess the interface of petsc-mumps has some problem, i.e. alignment.
>> > Please get a stack trace with the debugger.
>> > Matt
>> >>> Yes, petsc-dev works. Please merge the update to petsc-3.2.
>> >> Parmetis 4.0 was released after PETSc 3.2 so it will not be updated to
>> >> work with it. In general, software projects don't update a previous release
>> >> on a dependent package update. Please use petsc-dev or wait until PETSc 3.3.
>> > What most experimenters take for granted before they begin their experiments
>> > is infinitely more interesting than any results to which their experiments
>> > lead.
>> > -- Norbert Wiener
