[petsc-users] MUMPS solver crash with petsc-3.2
Gong Ding
gdiso at ustc.edu
Wed Dec 7 02:53:47 CST 2011
I remove #define PETSCHAVE_DEBUG in the petscconf.h, and the debug version runs.
The dbx report is:
Segmentation fault in dmumps_462 at line 6743 in file "dmumps_part4.F"
6743 IF(DIM.EQ.1) THEN
(dbx) where
dmumps_462(internal error: assertion failed at line 3650 in file frame.c
??, internal error: assertion failed at line 3650 in file frame.c
??), line 6743 in "dmumps_part4.F"
> On Tue, Dec 6, 2011 at 10:54 PM, Gong Ding <gdiso at ustc.edu> wrote:
> > I can only analysis the core file at present.
> > It reported
> > Program terminated with signal 11, Segmentation fault.
> > #0 0x000000010217319c in dmumps_462 ()
> > Run program with -info, the output is
> > Entering DMUMPS driver with JOB, N, NZ = 1 49 217
> > DMUMPS 4.10.0
> > L U Solver for unsymmetric matrices
> > Type of parallelism: Working host
> > ****** ANALYSIS STEP ********
> > Resetting candidate strategy to 0 because NSLAVES=1
> > ... Structural symmetry (in percent)= 100
> > Density: NBdense, Average, Median = 0 3 3
> > ... No column permutation
> > Ordering based on AMF
> > Program terminated with signal SIGSEGV, Segmentation fault.
> > The example in src/ksp/ksp/examples/tests/ex3 run ok -- it solves a small
> > linear problem.
> > Also, if I reduce the matrix size to ~20x20, no crash happen.
> > I'll try to provide more information.
> > On Tue, Dec 6, 2011 at 12:52 AM, Gong Ding <gdiso at ustc.edu> wrote:
> >> Bad news.
> >> MUMPS still crash on AIX/PPC.
> >> I tried petsc-3.1, 3.2 and dev. All of them crash with ERROR: 0031-250
> >> task 0: Segmentation fault.
> >> I guess the interface of petsc-mumps has some problem, i.e. alignment.
> > Please get a stack trace with the debugger.
> > Matt
> >>> Yes, petsc-dev works. Please merge the update to petsc-3.2.
> >> Parmetis 4.0 was released after PETSc 3.2 so it will not be updated to
> >> work with it. In general, software projects don't update a previous release
> >> on a dependent package update. Please use petsc-dev or wait until PETSc 3.3.
> > What most experimenters take for granted before they begin their experiments
> > is infinitely more interesting than any results to which their experiments
> > lead.
> > -- Norbert Wiener
