[petsc-users] about DA
Likun Tan
likunt at andrew.cmu.edu
Wed Aug 31 17:37:06 CDT 2011
Likun
On Wed, August 31, 2011 5:11 pm, Ethan Coon wrote:
> On Wed, 2011-08-31 at 16:23 -0400, Likun Tan wrote:
>> Hello,
>> I have a quick question about DA. When use DAVecGetArray() to set
>> values to the array and run the program with mpiexec, does
>> DAVecGetArray()
>> compute in parallel?
> DAVecGetArray() only gives you access to the local portion (plus any
> ghost nodes) of the global vec. The portion of the data you get is indexed
> by global numbering, so the indices into the pointer should range from
> xs --> xs+m
> where these values are given by
> DAGetGhostCorners() or DAGetCorners()
> http://www.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-current/docs/manual
> pages/DA/DAGetGhostCorners.html#DAGetGhostCorners
> So yes, you should only do the local portion of the calculation to set
> set the values.
> Ethan
>> Thanks in advance,
>> Likun
> Ethan Coon
> Post-Doctoral Researcher
> Applied Mathematics - T-5
> Los Alamos National Laboratory
> 505-665-8289
> http://www.ldeo.columbia.edu/~ecoon/
