[petsc-users] about DA
Ethan Coon ecoon at lanl.gov
Wed Aug 31 16:11:30 CDT 2011
On Wed, 2011-08-31 at 16:23 -0400, Likun Tan wrote:
> Hello,
> I have a quick question about DA. When use DAVecGetArray() to set values
> to the array and run the program with mpiexec, does DAVecGetArray()
> compute in parallel?
DAVecGetArray() only gives you access to the local portion (plus any
ghost nodes) of the global vec.  The portion of the data you get is
indexed by global numbering, so the indices into the pointer should
range from
xs --> xs+m
where these values are given by
DAGetGhostCorners() or DAGetCorners()
http://www.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-current/docs/manualpages/DA/DAGetGhostCorners.html#DAGetGhostCorners
So yes, you should only do the local portion of the calculation to set
set the values.
Ethan
> Thanks in advance,
> Likun
Ethan Coon
Post-Doctoral Researcher
Applied Mathematics - T-5
Los Alamos National Laboratory
505-665-8289
http://www.ldeo.columbia.edu/~ecoon/
