[petsc-users] The default nonzero pattern for SuperLU_dist.
Wed Aug 31 16:42:41 CDT 2011
On Aug 31, 2011, at 4:40 PM, Xuefei (Rebecca) Yuan wrote:
> Hello all,
> Is the default nonzero pattern for SuperLU_dist is SAME_NONZERO_PATTERN?
   There is no default nonzero pattern. You always must set it when you call KSPSetOperators() or in your SNES FormFunction. The PETSc SUPERLU_dist interface allows either pattern and should work correctly.
    Barry
> Thanks!
> Best,
> Rebecca
