[petsc-users] performance issue solving multiple linear systems of the same size with the different preconditioning methods
Алексей Рязанов ram at ibrae.ac.ru
Fri Aug 26 16:29:59 CDT 2011
I have also checked KSPSolve behavior in my other PETSc programs and found
the same memory lack
27 августа 2011 г. 0:57 пользователь Алексей Рязанов <ram at ibrae.ac.ru>написал:
> Thank you for your response!
> I have the memory leak in both my programs. But I don't create plenty of
> vectors.
> My code looks like:
>   ***INIT_ALL***
>   PetscLogStageRegister("Iteration  :", &StageNum1);
>   PetscLogStagePush(StageNum1);
>   KSPSolve(dKSP, dvec_origRHS, dvec_Solution);
>   PetscLogStagePop();
>   ***DESTROY_ALL***
> And when I comment (or delete) KSPSolve, the log_summary output is:
> Memory usage is given in bytes:
> Creations   Destructions     Memory  Descendants' Mem Object Type
> Reports information only for process 0.
> --- Event Stage 0: Main Stage
> 1              1         729472     0   Application Order
> 1              1         225452     0   Distributed array
> 8              8       1533424     0   Vec
> 3              3             2604     0   Vec Scatter
> 8              8         613852     0   Index Set
> 1              1         221304     0   IS L to G Mapping
> 3              3     16603440     0   Matrix
> 1              1               832     0   Krylov Solver
> 1              1               688     0   Preconditioner
> 1              1               448     0   PetscRandom
> --- Event Stage 1: Iteration  :
> When I run the code with KSPSolve instruction, it gives me:
> 1              0            0            0      Application Order
> 1              0            0            0      Distributed array
> 8             17      4963592     0      Vec
> 3              2         1736         0      Vec Scatter
> 8             12      1425932     0      Index Set
> 1              0            0            0      IS L to G Mapping
> 3              5     50158132     0      Matrix
> 1              2         1664         0      Krylov Solver
> 1              2         1440         0      Preconditioner
> 0              1          544          0      Viewer
> 355        173   64692312     0      Vec
> 1              0            0            0      Vec Scatter
> 6              2         1024         0      Index Set
> 2              0            0            0      Matrix
> 1              0            0            0      Krylov Solver
> 1              0            0            0      Preconditioner
> 2              1          544          0      Viewer
> 2011/8/25 Jed Brown <jedbrown at mcs.anl.gov>
>> On Tue, Aug 23, 2011 at 02:37, Алексей Рязанов <ram at ibrae.ac.ru> wrote:
>>> When i delete the 4-5-6 part of 2nd, 1-2-3 works great! with exact like
>>> 1st results.
>>> When i delete the 1-2-3 part of 2nd, 4-5-6 works great! with exact like
>>> 1st results.
>>> All program (1-2-3-4-5-6) works badly.
>> From the -log_summary, you have a memory leak (many more vector creations
>> than destructions). Try running with -malloc_dump to debug it. Perhaps you
>> are creating a vector every time one of your functions is called? You should
>> also build --with-debugging=0 when looking at timing results. (You can keep
>> it in PETSC_ARCH=linux-gnu-opt.)
> Best regards,
> Alexey Ryazanov
> ______________________________________
> Nuclear Safety Institute of Russian Academy of Sciences
Best regards,
Alexey Ryazanov
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110827/7a2c2aea/attachment.htm>
