[petsc-users] performance issue solving multiple linear systems of the same size with the different preconditioning methods
Алексей Рязанов ram at ibrae.ac.ru
Fri Aug 26 15:57:01 CDT 2011
Thank you for your response!
I have the memory leak in both my programs. But I don't create plenty of
vectors.
My code looks like:
  ***INIT_ALL***
  PetscLogStageRegister("Iteration  :", &StageNum1);
  PetscLogStagePush(StageNum1);
  KSPSolve(dKSP, dvec_origRHS, dvec_Solution);
  PetscLogStagePop();
  ***DESTROY_ALL***
And when I comment (or delete) KSPSolve, the log_summary output is:
Memory usage is given in bytes:
Creations   Destructions     Memory  Descendants' Mem Object Type
Reports information only for process 0.
--- Event Stage 0: Main Stage
1              1         729472     0   Application Order
1              1         225452     0   Distributed array
8              8       1533424     0   Vec
3              3             2604     0   Vec Scatter
8              8         613852     0   Index Set
1              1         221304     0   IS L to G Mapping
3              3     16603440     0   Matrix
1              1               832     0   Krylov Solver
1              1               688     0   Preconditioner
1              1               448     0   PetscRandom
--- Event Stage 1: Iteration  :
When I run the code with KSPSolve instruction, it gives me:
1              0            0            0      Application Order
1              0            0            0      Distributed array
8             17      4963592     0      Vec
3              2         1736         0      Vec Scatter
8             12      1425932     0      Index Set
1              0            0            0      IS L to G Mapping
3              5     50158132     0      Matrix
1              2         1664         0      Krylov Solver
1              2         1440         0      Preconditioner
0              1          544          0      Viewer
355        173   64692312     0      Vec
1              0            0            0      Vec Scatter
6              2         1024         0      Index Set
2              0            0            0      Matrix
1              0            0            0      Krylov Solver
1              0            0            0      Preconditioner
2              1          544          0      Viewer
2011/8/25 Jed Brown <jedbrown at mcs.anl.gov>
> On Tue, Aug 23, 2011 at 02:37, Алексей Рязанов <ram at ibrae.ac.ru> wrote:
>> When i delete the 4-5-6 part of 2nd, 1-2-3 works great! with exact like
>> 1st results.
>> When i delete the 1-2-3 part of 2nd, 4-5-6 works great! with exact like
>> 1st results.
>> All program (1-2-3-4-5-6) works badly.
> From the -log_summary, you have a memory leak (many more vector creations
> than destructions). Try running with -malloc_dump to debug it. Perhaps you
> are creating a vector every time one of your functions is called? You should
> also build --with-debugging=0 when looking at timing results. (You can keep
> it in PETSC_ARCH=linux-gnu-opt.)
Best regards,
Alexey Ryazanov
______________________________________
Nuclear Safety Institute of Russian Academy of Sciences
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110827/cb4ecd94/attachment.htm>
