[petsc-users] Mesh partitioning and MPI calls
    Tabrez Ali
    stali at geology.wisc.edu
    Fri Aug 26 12:32:28 CDT 2011
Matt you were right
I was stupidly passing the wrong array (column major order) to Metis. My
code is in Fortran. I am surprised Metis didnt crash before.
Thanks anyway.
Tabrez
On 08/25/2011 11:49 PM, Matthew Knepley wrote:
> On Thu, Aug 25, 2011 at 9:15 PM, Tabrez Ali <stali at geology.wisc.edu
> <mailto:stali at geology.wisc.edu>> wrote:
>     Hello
>     I have an unstructured FE mesh which I am partitioning using Metis.
>     In the first case I only use the element partitioning info and
>     discard the nodal partitioning info i.e., the original ordering is
>     same as petsc's global ordering. In the second case I do use the
>     nodal partitioning info and nodes are distributed accordingly.
>     I would expect that in the 2nd scenario the total number of MPI
>     messages (at the end of the solve) would be lower than the 1st.
>     However I see that opposite is true. See the plot at
>     http://stali.freeshell.org/mpi.png
>     The number on the y axis is the last column of the "MPI messages:"
>     field from the -log_summary output.
>     Any ideas as to why this is happening. Does relying on total
>     number of MPI messages as a performance measure even make sense.
>     Please excuse my ignorance on the subject.
>     Alternatively what is a good way to measure how good the Metis
>     partitioning is?
> The thing to do here is take a case like 2 proc that can be completely
> understood, and get down to the details. I
> think there is a probably just a simple misunderstanding here.
> The first thing to check is that you are partitioning what you think.
> By default, Metis partitions the vertices of a graph,
> not elements, Thus you usually have to give Metis the "dual" of your
> finite element mesh. I would take a small (maybe
> 8 or 10 elements) mesh and look at the original and Metis partitions.
> If Metis does not look better, something is wrong.
>     Matt
>     Thanks in advance
>     Tabrez
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110826/81a9c330/attachment.htm>
