[petsc-users] performance issue solving multiple linear systems of the same size with the different preconditioning methods
Алексей Рязанов
ram at ibrae.ac.ru
Sun Aug 21 18:45:06 CDT 2011
Hello!
Could you please help me to solve my performance problem.
I have two programs.
In 1st I solve one system with one method and one preconditioner and get
some performance numbers.
I run it 9 times with 9 different preconditioners.
In 2nd I solve the same system with the same one method but with 9 different
preconditioners consecutively one after another.
I run it once and also get some performance info.
In the 2nd case I have 2-5 times worse results, depending on used method.
Each KSPSolve procedure placed in its own stage of course, so I can compare
times, flops, messages an so..
I can see the difference but cant explain and eliminate it.
For example for -ksp_type cgs -pc_type asm -sub_pc_type jacobi -sub_ksp_type
preonly:
Summary of Stages: ----- Time ------ ----- Flops
----- --- Messages --- -- Message Lengths -- -- Reductions --
Avg %Total Avg
%Total counts %Total Avg %Total counts %Total
one stage frome 2nd: 5.5145e+00 14.9% 1.2336e+09 13.2% 2.494e+03
22.4% 3.230e+03 22.2% 2.250e+03 18.5%
the once stage from 1st: 2.7541e+00 93.1% 1.2336e+09 99.8% 2.508e+03
99.3% 1.470e+04 97.4% 2.266e+03 88.0%
My programs are pretty equivalent except the part with definition of
preconditioners and the number of called KSPSolve procedures.
I mean they use equal matrices, equally assemble them, use equal right hand
sides, equal convergence monitors.
Actually the 2nd one was made from the 1st.
In 1st i use KSPSetFromOptions(KSP); and then just set the -ksp_type
-pc_type -sub_pc_type -sub_ksp_type keys from command line
In 2d i use for for nonblock PC:
KSPGetPC(dKSP, &dPC);
PCSetType(dPC, PCJACOBI);
and for block PC:
PCSetType(dPC, PCASM);
KSPSetUp(dKSP);
PCSetUp(dPC);
PCASMGetSubKSP(dPC, &n_local, &first_local, &ASMSubKSP);
for (i=0; i<n_local; i++)
KSPGetPC(ASMSubKSP[i], &(SubPC[i]));
PCSetType(SubPC[i], PCJACOBI);
Im sure there is a mistake somewhere. Because 1st program compares Jacobi
and ASM-Jacobi preconditioners on my problem on the same KSP and tells me
that ASM-Jacobi is better and the 2nd shows otherwise results.
All tests I run on the 2cores machine.
Thank you in advance.
Best regards,
Alexey Ryazanov
______________________________________
Nuclear Safety Institute of Russian Academy of Sciences
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110822/f523f14e/attachment.htm>
