[petsc-users] Freeing Preconditioner Matrix Space
    Barry Smith
    bsmith at mcs.anl.gov
    Sun Aug 21 17:22:28 CDT 2011
  You don't need to put that in the PETSc source. Just built it in the same directory you build your application and link it in like any of your application code. You will need to stick
#include <private/pcimpl.h>     /*I "petscpc.h" I*/
typedef struct {
  PetscInt   n, n_local, n_local_true;
  PetscInt   overlap;             /* overlap requested by user */
  KSP        *ksp;                /* linear solvers for each block */
  VecScatter *restriction;        /* mapping from global to subregion */
  VecScatter *localization;       /* mapping from overlapping to non-overlapping subregion */
  VecScatter *prolongation;       /* mapping from subregion to global */
  Vec        *x,*y,*y_local;      /* work vectors */
  IS         *is;                 /* index set that defines each overlapping subdomain */
  IS         *is_local;           /* index set that defines each non-overlapping subdomain, may be NULL */
  Mat        *mat,*pmat;          /* mat is not currently used */
  PCASMType  type;                /* use reduced interpolation, restriction or both */
  PetscBool  type_set;            /* if user set this value (so won't change it for symmetric problems) */
  PetscBool  same_local_solves;   /* flag indicating whether all local solvers are same */
  PetscBool  sort_indices;        /* flag to sort subdomain indices */
} PC_ASM;
before the subroutine.
  Barry
On Aug 21, 2011, at 3:24 PM, Gaetan Kenway wrote:
> Hello
> I am attempting to implement a "hack" that was posted on the list a while back. I'm working with the adjoint linear system solver for a CFD solver. I'm using the ASM (or Block Jacobi) preconditioner with ILU(p) on each of the sub-domains. I use a different Preconditioner matrix (Pmat) than the actual jacobian. What I want to do is destroy the Pmat memory after the ILU factorization is performed. The hack that was posted is copied below:
>  PCASMFreeSpace(PC pc)
>   PC_ASM         *osm = (PC_ASM*)pc->data;
>   PetscErrorCode ierr;
>      if (osm->pmat) {
>     if (osm->n_local_true > 0) {
>       ierr = MatDestroyMatrices(osm->n_local_true,&osm->pmat);CHKERRQ(ierr);
>   osm->pmat = 0;
>   if (pc->pmat) {ierr = MatDestroy(pc->pmat);CHKERRQ(ierr); pc->pmat = 0;}
>   return 0;
> However, I've had no luck actually getting the function compiled into petsc. There are no erorrs reported with i type "make" in the asm directory, but when I try to use the function in my application it can't find the symbol while linking. Where does it go in the asm.c file? Does it use "static PetscErrorCode" or "PetscErrorCode PETSCKSP_DLLEXPORT"? Does it have to be added to the .h include files? What has to be done for it work with Fortran?
> Any suggestions would be greatly appreciated.  This represents a significant chunk of my application's memory (10%-30%) and as such its too much to ignore.   Also is there any chance something like this would make it into an actual PETSc release?
> Gaetan
