[petsc-users] Creating a 2d geometry by using vector
Alan Wei
zhenglun.wei at gmail.com
Fri Aug 19 14:55:16 CDT 2011
Dear Barry,
In ex19, the X is a kinda of global vec, while the x is a local vec.
Since DAVecGetArray makes the x and X sharing the same actual vector data,
the vec X is, actually, a global copy of the vec x, isnt it?
best,
Alan
On Thu, Aug 18, 2011 at 10:12 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Aug 18, 2011, at 9:40 PM, Alan Wei wrote:
> > Dear Barry,
> > That is really a great idea, and it is something that I want. I've
> never noticed that the structure in C is so marvelous. However, I have a
> further question. In that example, a variable x is defined like Field **x,
> and DAVecGetArray(da,X,&x). I wonder if there is any relationship between
> da, X and x after using DAVecGetArray. Or it just a prerequisite for using
> the nice notation of 'x'.
> The only real relationship is that x looks into the X data structure to
> allow you to access the data as if it were in simple arrays. In other words
> the x and X share the same actual vector data.
> Barry
> > thanks,
> > Alan
> > On Thu, Aug 18, 2011 at 9:09 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > Alan,
> > I'm not sure what you are getting at but we commonly use tricks like
> (see src/snes/examples/tutorials/ex19.c)
> > typedef struct {
> > PetscScalar u,v,omega,temp;
> > } Field;
> > Then in this case use a DMDAVecGetArray() to get f and x and then have
> nice notation like
> > f[j][i].u = x[j][i].u;
> > f[j][i].v = x[j][i].v;
> > f[j][i].omega = x[j][i].omega - (x[j][i+1].v - x[j][i].v)*dhx;
> > f[j][i].temp = x[j][i].temp;
> > note that this means the values are stored interlaced in the vector.
> > Barry
> > On Aug 18, 2011, at 9:03 PM, Alan Wei wrote:
> > > Dear All,
> > > I'm trying to 'draw' a 2-D cylinder in PETSc. It simply restore the
> x and y coordinate values in two arrays. I wonder if I can use Vec in PETSc
> to implement it (i.e. defining a vec circle) so that I can call its x or y
> coordinate by circle.x or circle.y. Is this possible? also, is this a better
> way than just defining it as two arrays, i.e. x[ ] and y[ ].
> > > thanks in advance,
> > > Alan
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110819/3f968e64/attachment.htm>
