[petsc-users] Creating a 2d geometry by using vector
Barry Smith
bsmith at mcs.anl.gov
Thu Aug 18 22:12:04 CDT 2011
On Aug 18, 2011, at 9:40 PM, Alan Wei wrote:
> Dear Barry,
> That is really a great idea, and it is something that I want. I've never noticed that the structure in C is so marvelous. However, I have a further question. In that example, a variable x is defined like Field **x, and DAVecGetArray(da,X,&x). I wonder if there is any relationship between da, X and x after using DAVecGetArray. Or it just a prerequisite for using the nice notation of 'x'.
The only real relationship is that x looks into the X data structure to allow you to access the data as if it were in simple arrays. In other words the x and X share the same actual vector data.
Barry
> thanks,
> Alan
> On Thu, Aug 18, 2011 at 9:09 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> Alan,
> I'm not sure what you are getting at but we commonly use tricks like (see src/snes/examples/tutorials/ex19.c)
> typedef struct {
> PetscScalar u,v,omega,temp;
> } Field;
> Then in this case use a DMDAVecGetArray() to get f and x and then have nice notation like
> f[j][i].u = x[j][i].u;
> f[j][i].v = x[j][i].v;
> f[j][i].omega = x[j][i].omega - (x[j][i+1].v - x[j][i].v)*dhx;
> f[j][i].temp = x[j][i].temp;
> note that this means the values are stored interlaced in the vector.
> Barry
> On Aug 18, 2011, at 9:03 PM, Alan Wei wrote:
> > Dear All,
> > I'm trying to 'draw' a 2-D cylinder in PETSc. It simply restore the x and y coordinate values in two arrays. I wonder if I can use Vec in PETSc to implement it (i.e. defining a vec circle) so that I can call its x or y coordinate by circle.x or circle.y. Is this possible? also, is this a better way than just defining it as two arrays, i.e. x[ ] and y[ ].
> > thanks in advance,
> > Alan
