[petsc-users] external libHYPRE is installed in lib64 and causes a configure error
Wed Aug 17 22:24:18 CDT 2011
  Send configure.log to petsc-maint at mcs.anl.gov
On Aug 17, 2011, at 10:15 PM, Andre Massing wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Dear all
> Today I wanted to install petsc-3.1-p8 on a openSUSE 11.4 (which I
> have done successfully in the past) but some reason I got a configure
> error
>                      Configuring hypre; this may take several minutes
>                      Compiling hypre; this may take several minutes
> TESTING: check from
> config.libraries(/home/andre/Work/software/FEniCS-dependencies/src/testdir/petsc-3.1-p8/config/BuildSystem/config/libraries.py:133)
>         UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log
> for details):
> Downloaded hypre could not be used. Please check install in
> /home/andre/Work/software/FEniCS-dependencies/src/testdir/petsc-3.1-p8/linux-gnu-cxx-opt
> when I executed
> export
> PARMETIS_DIR="/home/andre/Work/software/FEniCS-dependencies\/install"
> ./config/configure.py --with-debugging=0 --with-shared=1 \
> --with-clanguage=cxx --with-parmetis=1 \
> --with-parmetisdir=${PARMETIS_DIR} \
> --download-umfpack=1 --download-hypre=1
> The main reason seems to be that the libHYPRE.a for some reason is
> copied to
> linux-gnu-cxx-opt/lib64/
> and not to
> According to the configure.log file
> Executing: mpicxx  -o conftest    -Wall -Wwrite-strings
> - -Wno-strict-aliasing -O  conftest.o
> -Wl,-rpath,/home/andre/Work/software/FEniCS-dependencies/src/testdir/petsc-3.1-p8/linux-gnu-cxx-opt/lib
> -L/home/andre/Work/software/FEniCS-dependencies/src/testdir/petsc-3.1-p8/linux-gnu-cxx-opt/lib
> - -lHYPRE -llapack -lblas -Wl,-rpath,/usr/lib64/mpi/gcc/openmpi/lib64
> - -L/usr/lib64/mpi/gcc/openmpi/lib64
> - -Wl,-rpath,/usr/lib64/gcc/x86_64-suse-linux/4.5
> - -L/usr/lib64/gcc/x86_64-suse-linux/4.5
> - -Wl,-rpath,/usr/x86_64-suse-linux/lib -L/usr/x86_64-suse-linux/lib
> - -ldl -lmpi -lopen-rte -lopen-pal -lnsl -lutil -lgcc_s -lpthread
> - -lmpi_f90 -lmpi_f77 -lgfortran -lm -lm
> - -Wl,-rpath,/usr/lib64/mpi/gcc/openmpi/lib64
> - -Wl,-rpath,/usr/x86_64-suse-linux/lib -lm -lm
> - -ldl -lmpi -lopen-rte -lopen-pal -lnsl -lutil -lgcc_s -lpthread -ldl
> sh:
> Possible ERROR while running linker:
> /usr/lib64/gcc/x86_64-suse-linux/4.5/../../../../x86_64-suse-linux/bin/ld:
> cannot find -lHYPRE
> collect2: ld returned 1 exit status
> the lib64 location of libHYPRE.a causes a linking error since the
> above command does only include
> Do you have any idea what could cause that location mismatch? Is the
> libHYPRE.a location wrong or does the mpicxx command above omit a
> needed library path? This error is kind of strange since I have an old
> installation (same petsc version, same OS) where everything went
> through...
> Any pointers are very much appreciated!!
> Cheers,
> Andre
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v2.0.18 (GNU/Linux)
> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
> iQEcBAEBAgAGBQJOTIPrAAoJEA79ggnbq9dmwDAIAJCM5SfUfh3I+qCr9fPG3pMW
> Spzc+hrJNQyZegIZIqR1RgHwCue0Fgkh2vmvglGmzYsfMiHl5CI88qBYxnxSF0wH
> imvZoXXeLqpy1pmPn2RtB4gRaMsarx1AMpnsVn0A6aIPEkn07rfJOEf19egSxO/r
> Yr+fnY2a4yXPrC4dfzgFjdsGHWSXCabzMwznQQldhQ+kF7bQ5V5InPPTYal6qSLm
> /0sz7ZwAsyuL+29vj8+8aD4uVN/yVEDIGJtNg5RburBK4FDqEcZOsrQMjZGNB/6B
> iPSJoQ8XK5b6yKqlzCmU9Qu9i/yxvKezUUTYMpGRK6Gd5mBEQSWOYz0jdz/CfYo=
> =1QvU
> -----END PGP SIGNATURE-----
