[petsc-users] external libHYPRE is installed in lib64 and causes a	configure error
    Andre Massing
    massing at simula.no
    Wed Aug 17 22:15:55 CDT 2011
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Dear all
Today I wanted to install petsc-3.1-p8 on a openSUSE 11.4 (which I
have done successfully in the past) but some reason I got a configure
error
                      Configuring hypre; this may take several minutes
                      Compiling hypre; this may take several minutes
TESTING: check from
config.libraries(/home/andre/Work/software/FEniCS-dependencies/src/testdir/petsc-3.1-p8/config/BuildSystem/config/libraries.py:133)
         UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log
for details):
Downloaded hypre could not be used. Please check install in
/home/andre/Work/software/FEniCS-dependencies/src/testdir/petsc-3.1-p8/linux-gnu-cxx-opt
when I executed
export
PARMETIS_DIR="/home/andre/Work/software/FEniCS-dependencies\/install"
./config/configure.py --with-debugging=0 --with-shared=1 \
 --with-clanguage=cxx --with-parmetis=1 \
 --with-parmetisdir=${PARMETIS_DIR} \
 --download-umfpack=1 --download-hypre=1
The main reason seems to be that the libHYPRE.a for some reason is
copied to
linux-gnu-cxx-opt/lib64/
and not to
According to the configure.log file
Executing: mpicxx  -o conftest    -Wall -Wwrite-strings
- -Wno-strict-aliasing -O  conftest.o
-Wl,-rpath,/home/andre/Work/software/FEniCS-dependencies/src/testdir/petsc-3.1-p8/linux-gnu-cxx-opt/lib
-L/home/andre/Work/software/FEniCS-dependencies/src/testdir/petsc-3.1-p8/linux-gnu-cxx-opt/lib
- -lHYPRE -llapack -lblas -Wl,-rpath,/usr/lib64/mpi/gcc/openmpi/lib64
- -L/usr/lib64/mpi/gcc/openmpi/lib64
- -Wl,-rpath,/usr/lib64/gcc/x86_64-suse-linux/4.5
- -L/usr/lib64/gcc/x86_64-suse-linux/4.5
- -Wl,-rpath,/usr/x86_64-suse-linux/lib -L/usr/x86_64-suse-linux/lib
- -ldl -lmpi -lopen-rte -lopen-pal -lnsl -lutil -lgcc_s -lpthread
- -lmpi_f90 -lmpi_f77 -lgfortran -lm -lm
- -Wl,-rpath,/usr/lib64/mpi/gcc/openmpi/lib64
- -Wl,-rpath,/usr/x86_64-suse-linux/lib -lm -lm
- -ldl -lmpi -lopen-rte -lopen-pal -lnsl -lutil -lgcc_s -lpthread -ldl
sh:
Possible ERROR while running linker:
/usr/lib64/gcc/x86_64-suse-linux/4.5/../../../../x86_64-suse-linux/bin/ld:
cannot find -lHYPRE
collect2: ld returned 1 exit status
the lib64 location of libHYPRE.a causes a linking error since the
above command does only include
Do you have any idea what could cause that location mismatch? Is the
libHYPRE.a location wrong or does the mpicxx command above omit a
needed library path? This error is kind of strange since I have an old
installation (same petsc version, same OS) where everything went
through...
Any pointers are very much appreciated!!
Cheers,
Andre
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v2.0.18 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
iQEcBAEBAgAGBQJOTIPrAAoJEA79ggnbq9dmwDAIAJCM5SfUfh3I+qCr9fPG3pMW
Spzc+hrJNQyZegIZIqR1RgHwCue0Fgkh2vmvglGmzYsfMiHl5CI88qBYxnxSF0wH
imvZoXXeLqpy1pmPn2RtB4gRaMsarx1AMpnsVn0A6aIPEkn07rfJOEf19egSxO/r
Yr+fnY2a4yXPrC4dfzgFjdsGHWSXCabzMwznQQldhQ+kF7bQ5V5InPPTYal6qSLm
/0sz7ZwAsyuL+29vj8+8aD4uVN/yVEDIGJtNg5RburBK4FDqEcZOsrQMjZGNB/6B
iPSJoQ8XK5b6yKqlzCmU9Qu9i/yxvKezUUTYMpGRK6Gd5mBEQSWOYz0jdz/CfYo=
=1QvU
-----END PGP SIGNATURE-----
