[petsc-users] problem with -malloc=0
Wed Aug 17 15:10:46 CDT 2011
On Aug 17, 2011, at 3:06 PM, Dominik Szczerba wrote:
> I tried that before too, also with off, the warning is still there:
> WARNING! There are options you set that were not used!
> WARNING! could be spelling mistake, etc!
> Option left: name:-malloc value: no
> This is not command line, this is in a string passed to
> PetscOptionsInsertString (but it should not matter, should it?)
  Won't work. The problem is startup options like -malloc are processed by PetscInitalize(). Since you set it after PetscInitialize() it won't have any affect. You need either on the command line, in the environmental variable PETSC_OPTIONS or in a file .petscrc either in your home directory or in the working directory.
   Barry
> Any ideas?
> Thanks, Dominik
> On Wed, Aug 17, 2011 at 8:19 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>  -malloc no
>>  The command line options in PETSc never take = in them
>>   Barry
>> On Aug 17, 2011, at 1:08 PM, Dominik Szczerba wrote:
>>> I am using -malloc=0 (as per the pdf documentation) to see:
>>> Option left: name:-malloc=0 no value
>>> What am I doing wrong?
>>> Many thanks,
>>> Dominik
