[petsc-users] Fatal error in MPI_Allreduce: Error message texts are not available[cli_9]: aborting job:
Sat Aug 6 09:31:20 CDT 2011
On Sat, 6 Aug 2011, Matthew Knepley wrote:
> On Sat, Aug 6, 2011 at 2:22 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> > The application is already started with -start_in_debugger. So you don't do
> > 'r run.xml'
> > You place a break point at relavent locations - and then do 'c' for
> > continue
> Satish is right. Also, at this point you can set the arguments using
>   set args run.xml
Actually the program is already started - so this can't be reset. Just set the arguments at start time.
mpiexec -n 4 program run.xml -start_in_debugger
[or whatever scheme is normally when the code is used without -start_in_debugger]
Satish
> > (gdb) b PetscError
> > (gdb) c
> > Satish
