[petsc-users] Fatal error in MPI_Allreduce: Error message texts are not available[cli_9]: aborting job:
    Satish Balay
    balay at mcs.anl.gov
    Sat Aug  6 09:22:42 CDT 2011
On Sat, 6 Aug 2011, Dominik Szczerba wrote:
> >> Also, run with -start_in_debugger and get a stack trace when it fails.
> >>    Matt
> > I get:
> > [0]PETSC ERROR: PETSC: Attaching gdb to
> > /home/dsz/build/framework-debug/trunk/bin/sm3t4mpi of pid 12238 on
> > display localhost:11.0 on machine nexo
> OK after long waiting all 12 gdb windows showed up. Starting the app
> with its args leads to:
> Reading symbols from /home/dsz/build/framework-debug/trunk/bin/sm3t4mpi...done.
> Attaching to program:
> /home/dsz/build/framework-debug/trunk/bin/sm3t4mpi, process 12241
> ptrace: No such process.
> /home/dsz/data/test-solve/SM/box/run3/12241: No such file or directory.
> (gdb)  r run.xml
> Starting program: /home/dsz/build/framework-debug/trunk/bin/sm3t4mpi run.xml
> [Thread debugging using libthread_db enabled]
> [cli_3]: PMIU_parse_keyvals: unexpected key delimiter at character 54 in cmd
> [cli_3]: parse_kevals failed -1
The application is already started with -start_in_debugger. So you don't do 'r run.xml'
You place a break point at relavent locations - and then do 'c' for continue
(gdb) b PetscError
(gdb) c
Satish
