[petsc-users] Fatal error in MPI_Allreduce: Error message texts are not available[cli_9]: aborting job:
Matthew Knepley
knepley at gmail.com
Sat Aug 6 01:26:14 CDT 2011
On Sat, Aug 6, 2011 at 6:19 AM, Dominik Szczerba <dominik at itis.ethz.ch>wrote:
> >> Also, run with -start_in_debugger and get a stack trace when it fails.
> >> Matt
> > I get:
> > [0]PETSC ERROR: PETSC: Attaching gdb to
> > /home/dsz/build/framework-debug/trunk/bin/sm3t4mpi of pid 12238 on
> > display localhost:11.0 on machine nexo
> OK after long waiting all 12 gdb windows showed up. Starting the app
> with its args leads to:
> Reading symbols from
> /home/dsz/build/framework-debug/trunk/bin/sm3t4mpi...done.
> Attaching to program:
> /home/dsz/build/framework-debug/trunk/bin/sm3t4mpi, process 12241
> ptrace: No such process.
> /home/dsz/data/test-solve/SM/box/run3/12241: No such file or directory.
> (gdb) r run.xml
> Starting program: /home/dsz/build/framework-debug/trunk/bin/sm3t4mpi
> run.xml
> [Thread debugging using libthread_db enabled]
> [cli_3]: PMIU_parse_keyvals: unexpected key delimiter at character 54 in
> cmd
> [cli_3]: parse_kevals failed -1
> Any thoughts?
Google. That is an MPICH error, so somehow you are providing bad arugments
to MPICH.
Matt
> Thanks
> Dominik
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110806/a2e34ac1/attachment-0001.htm>
