[petsc-users] PETSC ERROR: Caught signal number 15 Terminate
Aron Ahmadia
aron.ahmadia at kaust.edu.sa
Fri Aug 5 05:04:23 CDT 2011
"But I encounter a new problem, the situation is:****
1, the matrix is big, and can be partitioned to several blocks;****
2, started several threads to handle each block of matrix;****
3, integrated all block matrices together."****
You should be using PETSc+MPI to handle this distribution for you.
Threading will not get around any memory limits for a single process that
your system may have.
A
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110805/ad8833db/attachment.htm>
