[petsc-users] PETSC ERROR: Caught signal number 15 Terminate
Debao Shao
Debao.Shao at brion.com
Fri Aug 5 05:00:07 CDT 2011
Thanks a lot, Barry and Matthew.
I found the root cause of my problem.
1, I put "PetscInitialize" at the beginning of main, and "PetscInitialize" registers a signal handler to capture "SIGTERM";
2, the problem ran in server side will send SIGTERM to kill all of clients after one stage is done.
3, then, unfortunately, the signal "SIGTERM" is caught by the signal handler installed by "PetscInitialize", and caused to abort.
With changing the position of "PetscInitialize", I fixed the issue.
But I encounter a new problem, the situation is:
1, the matrix is big, and can be partitioned to several blocks;
2, started several threads to handle each block of matrix;
3, integrated all block matrices together.
Again, the program crashed with reporting:
"[0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation, probably memory access out of range"
My libpetsc.a is built with option "--with-mpi=0 --with-debugging=0 -with-log=0 -with-info=0".
Will it support this type of multiple threads?
Please give your comments, thanks a lot.
Debao
-----Original Message-----
From: petsc-users-bounces at mcs.anl.gov [mailto:petsc-users-bounces at mcs.anl.gov] On Behalf Of Barry Smith
Sent: Friday, August 05, 2011 10:57 AM
To: PETSc users list
Subject: Re: [petsc-users] PETSC ERROR: Caught signal number 15 Terminate
On Aug 4, 2011, at 8:54 PM, Debao Shao wrote:
> I get this error after a long process.
> For example, I have 4 jobs to do, the program may crash after done 1 job or 2, 3, 4 jobs. Also, sometimes, the program can run finished successfully.
The program is not crashing. The batch system is kicking out the job, probably because it thinks it has run out of time. You'll need to set a longer time for the batch system.
Barry
> Thanks,
> Debao
> Sent: Friday, August 05, 2011 10:43 AM
> On Aug 4, 2011, at 8:38 PM, Debao Shao wrote:
>> Doesn't SEGV fault is signal 11?
> Yes., 15 is a software terminate single sent from some other process hence the error message:
>> Caught signal number 15 Terminate: Somet process (or the batch system) has told this process to end
> I've seen some batch systems send this single when they think you have run out of time. There may be other reasons as well. Do you get this right away or after a long time?
> Barry
>> From: petsc-users-bounces at mcs.anl.gov [mailto:petsc-users-bounces at mcs.anl.gov] On Behalf Of Matthew Knepley
>> Sent: Friday, August 05, 2011 10:35 AM
>> On Fri, Aug 5, 2011 at 2:33 AM, Debao Shao <Debao.Shao at brion.com> wrote:
>> So the real problem is the wrong usage of "PetscInitialize(0, 0, 0, 0 )", but I do have many successive runs before with this setting.
>> Any kind of memory overwrite gives an SEGV. So other code, making a different error will give that too.
>> Matt
>> Thanks,
>> Debao
>> Sent: Friday, August 05, 2011 10:25 AM
>> On Fri, Aug 5, 2011 at 2:20 AM, Debao Shao <Debao.Shao at brion.com> wrote:
>> DA:
>> Sometimes I may encounter crashing when using PETSc, it doesn't happen always.
>> [0]PETSC ERROR: ------------------------------------------------------------------------
>> [0]PETSC ERROR: Caught signal number 15 Terminate: Somet process (or the batch system) has told this process to end
>> [0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
>> [0]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/petsc-as/documentation/troubleshooting.html#Signal[0]PETSC ERROR: or try http://valgrind.org on GNU/linux
>> and Apple Mac OS X to find memory corruption errors
>> [0]PETSC ERROR: configure using --with-debugging=yes, recompile, link, and run
>> [0]PETSC ERROR: to get more information on the crash.
>> [0]PETSC ERROR: --------------------- Error Message ------------------------------------
>> [0]PETSC ERROR: Signal received!
>> [0]PETSC ERROR: Petsc Release Version 3.1.0, Patch 8, Thu Mar 17 13:37:48 CDT 2011
>> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
>> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
>> [0]PETSC ERROR: See docs/index.html for manual pages.
>> [0]PETSC ERROR: Unknown Name on a linux-gnu named r0leaf17 by tachyon Thu Aug 4 04:04:19 2011
>> [0]PETSC ERROR: Libraries linked from /home/dshao/dev_t2k/third_party/OOQP/OOQP-0.99.19/extras/petsc-3.1-p8/linux-gnu-c-debug/lib
>> [0]PETSC ERROR: Configure run at Thu Apr 21 18:09:19 2011
>> [0]PETSC ERROR: Configure options --with-mpi=0 --with-debugging=0 -with-log=0 -with-info=0
>> [0]PETSC ERROR: User provided function() line 0 in unknown directory unknown file
>> Do you happen to know the possible cause?
>> I also have a question about the usage of "PetscInitialize" & "PetscFinalize". I can't totally understand them from the manual.
>> Now, I wrote it as:
>> Int main(int argc, char **argv)
>> PetscInitialize(0, 0, 0, 0 );
>> This is not a valid call. Try
>> PetscInitialize(&argc, &argv, 0, 0);
>> Signal 15 is a segmentation fault, which means an illegal memory read or write.
>> Matt
>> VerifyApp app(argc, argv);
>> app.Initialize();
>> app.Run();
>> PetscFinalize();
>> return 0;
>> Then, built a binary, say "verify", and executed "verify" on a server first, then, started another "verify" on client by server.
>> The program ran at client side can be multiple processes and multiple threads.
>> Is my usage correct?
>> Your answer is appreciated.
>> Thanks,
>> Debao
>> -- The information contained in this communication and any attachments is confidential and may be privileged, and is for the sole use of the intended recipient(s). Any unauthorized review, use, disclosure or distribution is prohibited. Unless explicitly stated otherwise in the body of this communication or the attachment thereto (if any), the information is provided on an AS-IS basis without any express or implied warranties or liabilities. To the extent you are relying on this information, you are doing so at your own risk. If you are not the intended recipient, please notify the sender immediately by replying to this message and destroy all copies of this message and any attachments. ASML is neither liable for the proper and complete transmission of the information contained in this communication, nor for any delay in its receipt.
>> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
>> -- Norbert Wiener
>> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110805/370c643a/attachment-0001.htm>
