[petsc-users] compile own solver with petsc-dev
Thu Aug 4 17:00:02 CDT 2011
On Thu, 4 Aug 2011, Ping Rong wrote:
> Hello all,
> I have developed a ksp solver, which is located in /src/ksp/ksp/impls/xxx. I
> used petsc-3.1.0-p8, when I changed the solver code, I updated petsc with
>         cd /src/ksp/ksp/impls/xxx
>         make ACTION=libfast
>         cd $PETSC-ROOT
>         make ranlib shared
> I have recently started using petsc-dev, which switches to cmake to compile
> the library.
If configure finds cmake - then 'make all' defaults to cmake build. Its
still possible to get the old build with:
make all-legacy
> By the above method, the compilation still went through, however,
> when I try to link my program to libpetsc.so, it gives errors of unresolved
> symbols. Is there a new way to partially update the library without running
> the whole compilation over?  any help would be appreciated!
With cmake build - you could do: [anywhere in petsc tree]
make cmake
Satish
