[petsc-users] compile own solver with petsc-dev
Ping Rong ping.rong at tuhh.de
Thu Aug 4 16:55:52 CDT 2011
Hello all,
I have developed a ksp solver, which is located in
/src/ksp/ksp/impls/xxx. I used petsc-3.1.0-p8, when I changed the solver
code, I updated petsc with
         cd /src/ksp/ksp/impls/xxx
         make ACTION=libfast
         cd $PETSC-ROOT
         make ranlib shared
I have recently started using petsc-dev, which switches to cmake to
compile the library. By the above method, the compilation still went
through, however, when I try to link my program to libpetsc.so, it gives
errors of unresolved symbols. Is there a new way to partially update the
library without running the whole compilation over?  any help would be
appreciated!
Ping Rong, M.Sc.
Hamburg University of Technology
Institut of modelling and computation
Denickestraße 17 (Room 3031)
21073 Hamburg
Tel.: ++49 - (0)40 42878 2749
Fax:  ++49 - (0)40 42878 43533
Email: ping.rong at tuhh.de
