[petsc-users] PCFactorSetMatSolverPackage / PCFactorGetMatSolverPackage
Hong Zhang
hzhang at mcs.anl.gov
Tue Aug 2 09:48:24 CDT 2011
Clemens,
Petsc's LDLt decomposition is likely different from mumps' LDLt.
Are you sure you want Petsc's D, but use mumps LDLt?
I suggest sending a request to mumps developer on how to accessing mumps' D.
Hong
On Tue, Aug 2, 2011 at 8:12 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Tue, Aug 2, 2011 at 12:53 PM, Clemens Domanig
> <clemens.domanig at uibk.ac.at> wrote:
>> Maybe I should describe the hole problem.
>> I'm using MUMPS to make LDLt decomposition - all from command line.
>> But sometimes I need the diagonal entries (respectively the number of
>> negative entries) of the D matrix. But there is no way to get this
>> information back from MUMPS via petsc ( as far as I found out).
> Yes, we have no access to MUMPS internal data.
>> There was the suggestion to use MatGetIntertia but this is only for
>> off-diagonal-information.
> I am not sure what you mean by that.
>> So I used
>> PCSetType( prec, PCCHOLESKY);
>> PCFactorGetMatrix( prec, &M);
>> MatGetDiagonal( M, z);
>> It only works without MUMPS and gives me the diagonal entries I want in
>> Matrix M - although the entries are 1/x.
>> Vector z is full of zeros - only the last entry is the 'same' as in M (x
>> instead of 1/x).
>> So the idea was to somehow turn off MUMPS if I need the diagonal entries
>> and then turn it on again.
> Here is the easiest way to do it. Keep two complete solvers
> a) KSP with MUMPS
> b) KSP with Cholesky, give this one KSPSetOptionsPrefix(ksp, "diag_");
> That way -diag_pc_type cholesky will work. Then use the solver you want.
>> The problem with PCFactorGetMatSolverPackage is I didn't manage to use it.
>> const MatSolverPackage pack;
>> PCFactorGetMatSolverPackage( prec, &pack);
>> PetscSynchronizedPrintf( PETSC_COMM_WORLD, "%s\n", pack);
>> I expected 'mumps' as output but got 'H??????tdH3%0'
> It would seem its not yet setup.
> Matt
>> Thx
>> Matthew Knepley wrote:
>>> On Tue, Aug 2, 2011 at 9:28 AM, Clemens Domanig
>>> <clemens.domanig at uibk.ac.at <mailto:clemens.domanig at uibk.ac.at>> wrote:
>>> Hi,
>>> usually I'm using MUMPS by puting '-pc_factor_mat_solver_package
>>> mumps' into the .petscrc.
>>> Now I want to change in runtime between MUMPS and non-MUMPS so I
>>> tried to turn it on with
>>> PCFactorSetMatSolverPackage( pre, MAT_SOLVER_MUMPS);
>>> but I doesn't have any effect.
>>> This is complicated because you have to set this at the right time during
>>> the solver setup process.
>>> Command line arguments are much easier. However, you should call this
>>> after the preconditioner
>>> type is set, but before it is setup.
>>> I also have a problem with PCFactorGetMatSolverPackage(). How can I
>>> get back an output as described in the documentation that has the
>>> type 'const'?
>>> What is the problem? I do not understand?
>>> Matt
>>> Thx - Clemens
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
> What most experimenters take for granted before they begin their experiments
> is infinitely more interesting than any results to which their experiments
> lead.
> -- Norbert Wiener
