[petsc-users] PCFactorSetMatSolverPackage / PCFactorGetMatSolverPackage
Matthew Knepley
knepley at gmail.com
Tue Aug 2 08:12:33 CDT 2011
On Tue, Aug 2, 2011 at 12:53 PM, Clemens Domanig <clemens.domanig at uibk.ac.at
> wrote:
> Maybe I should describe the hole problem.
> I'm using MUMPS to make LDLt decomposition - all from command line.
> But sometimes I need the diagonal entries (respectively the number of
> negative entries) of the D matrix. But there is no way to get this
> information back from MUMPS via petsc ( as far as I found out).
Yes, we have no access to MUMPS internal data.
> There was the suggestion to use MatGetIntertia but this is only for
> off-diagonal-information.
I am not sure what you mean by that.
> So I used
> PCSetType( prec, PCCHOLESKY);
> PCFactorGetMatrix( prec, &M);
> MatGetDiagonal( M, z);
> It only works without MUMPS and gives me the diagonal entries I want in
> Matrix M - although the entries are 1/x.
> Vector z is full of zeros - only the last entry is the 'same' as in M (x
> instead of 1/x).
> So the idea was to somehow turn off MUMPS if I need the diagonal entries
> and then turn it on again.
Here is the easiest way to do it. Keep two complete solvers
a) KSP with MUMPS
b) KSP with Cholesky, give this one KSPSetOptionsPrefix(ksp, "diag_");
That way -diag_pc_type cholesky will work. Then use the solver you want.
> The problem with PCFactorGetMatSolverPackage is I didn't manage to use it.
> const MatSolverPackage pack;
> PCFactorGetMatSolverPackage( prec, &pack);
> PetscSynchronizedPrintf( PETSC_COMM_WORLD, "%s\n", pack);
> I expected 'mumps' as output but got 'H??????tdH3%0'
It would seem its not yet setup.
Matt
> Thx
> Matthew Knepley wrote:
> On Tue, Aug 2, 2011 at 9:28 AM, Clemens Domanig <
>> clemens.domanig at uibk.ac.at <mailto:clemens.domanig at uibk.**ac.at<clemens.domanig at uibk.ac.at>>>
>> wrote:
>> Hi,
>> usually I'm using MUMPS by puting '-pc_factor_mat_solver_package
>> mumps' into the .petscrc.
>> Now I want to change in runtime between MUMPS and non-MUMPS so I
>> tried to turn it on with
>> PCFactorSetMatSolverPackage( pre, MAT_SOLVER_MUMPS);
>> but I doesn't have any effect.
>> This is complicated because you have to set this at the right time during
>> the solver setup process.
>> Command line arguments are much easier. However, you should call this
>> after the preconditioner
>> type is set, but before it is setup.
>> I also have a problem with PCFactorGetMatSolverPackage(). How can I
>> get back an output as described in the documentation that has the
>> type 'const'?
>> What is the problem? I do not understand?
>> Matt
>> Thx - Clemens
>> experiments lead.
>> -- Norbert Wiener
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110802/c692cc64/attachment.htm>
